200+ woodworking book reviews
Sliding table alignment problem
Starry Chan
>I installed a Dewalt sliding table on a Delta contractor saw. I ran into a strange alignment problem. Here is the details.
1. The sliding table fence is 90 degree to both the blade and the Unifence across the entire travel length. The Unifence is parallel the blade as I have no problem of ripping. I also double checked this using the miter gauge and a dial indicator.
2. The sliding table miter slot is parallel to the fence. I checked this with a dial indicator.
3. However, the result cut piece always have the front edge longer than than the trailing edge. The wider the board, the larger the wedge-shaped cutoff piece. This means that the board is going into the blade at an angle. I cannot figure out how this can happen.
I would appreciate any feedback. If you are in the San Jose area and you have time over the weekend, I would appreciate you can pay a visit to my workshop so that I can show you how I do the alignment and the end result. Maybe through this exercise, you can tell me what I did wrong.
Re: Sliding table alignment problem
Ed Mulligan
>Might be something simple like the test piece is tapered?
Or the test piece is moving on the sliding table (relative to the sliding table fence?
Start looking at ALL the variables
Forrest Addy
>Problems like this are selsom quickly solved except by accident. Start looking at ALL the variables one by one to isolate the error so you can apply the most effective enemy. Look at the linearity of the table motion, or the tilt, taper, or twist of the slider's elements one by one. If you're not an expert with a level and a dial indicator by now you will be before you track down the error in your DeWaly slider.
Jim Dillon
>Starry,
My first guess would have been that the sliding table fence is not quite 90 degrees to the blade, but you said you checked it. Is there a way to tweak the fence? Another guess would be that the sled's runners are sloppy in the miter slots. Maybe there is a way to adjust them? Sawdust at the base of the sled fence can cause your problem as well. Just throwing out ideas, as I am not familiar with that sled.
Jim
One more thing...
Jim Dillon
>... and that is to check for square using the long edge that was against the fence, not the opposite edge. It is possible, as Ed alluded to, that the two long edges are not parallel to one another. Hence, if you checked for square using the edge that was not against the fence, the crosscut might appear to be non square. While my sleds do a good job, I always like to check for square to make sure everything is working OK. I have to make a conscious effort to remember to hold the square against the side that was against the fence. Actually, I usually check both sides. Hope you get things sorted out as a sled is very, very useful.
Jim
