delta spindle sander
jared
>Hello I have a delta BOSS spindle sander. I have had it for a few years but never really used it much. I would guess that my total usage is about 2-3 hours. I do use it for sanding the inside of band sawn boxes I make. Well sure enough last night I was sanding one and the spindle stopped going up and down. This morning I took the little plastic cover off the bottem of the motor and sure enough the plastic gear that drives the unit up and down was stripped off. For the life of me I cant see how any one would ever figure that an undersized plastic gear would ever hold up in that application. Has Delta come up with a fix for this thing or must it be replaced with another flimsy plastic gear? Is there a way to order parts directly from Delta? I havent done any research yet. THanks in advance Jared
Re: delta spindle sander
worrisome report
Bill Tindall, E.TN
>Its reports like these that damper my enthusiasm for buying new tools. Indeed, what were they thinking!
Re: worrisome report
Dan Mitchell
>"Indeed, what were they thinking!"
Simple. $$$$$$$
Jim Dillon
>Jared,
Same thing happened to me several years ago. Ordered a replacement from the online Delta parts website. IIRC, it cost more for the postage than the part. The replacement appeared to be the same material as the stripped one. I agree with you that this part should be made out of something more durable. While I never abused the sander, I use a very light touch now when sanding, and hope for the best. Definitely not a machine meant for production use IMHO.
Jim
Speaking of spindle sanders...
Mike in NC
>Does anyone have any experience with the Craftsman Spindle Sander (Model# 21500)? I saw this at my local Sears recently and then did some online research and it seems to be a nicer machine than the Delta.
Re: Speaking of spindle sanders...
Jim Dillon
>Mike,
I have no experience with the Craftsman spindle sander, but I was just flipping through my new September/October FWW (#207) and saw that they did a mini-review of that particular sander. Their conclusion (FWIW) was that it did a good job, but they still liked the Rigid EB4424 better, which they apparently reviewed in FWW #188.
Jim
