Best way to trim Cabinet Face frames *LINK*
Bernard
>After months of working on my bookshelf project in my spare time, I am virtually done. Several months ago, I had purchased the oak doors and stained and finished them, and put them safely in the guest bedroom to avoid any damage to them. I am ready to go install this project at my daughter's house this week, and started to install the doors last night. Oh no!
After installing a few sets of doors (2 doors per opening, no mullion), they actually overlap a bit, even after setting the width adjustment screw at max (it is a 3-way face frame hinge, virtually identical to the one in the link).
After the initial panic set in, I realized that my only solution (I think) is to shave the face frame where the hinge is attached, to effectively widen the openings. Probably 1/16" or 1/8" on each opening (a 6-foot wide cabinet with 3 openings, and then 2 of 27" cabinets), maybe one side only , maybe both.
My question is this: what would be the best way to do this to do this EFFECTIVELY and SAFELY? My thought was to set the cabinets back on their backs and then build a little jig guide, and then router it out. Or is there an easier way? I am open to any and all suggestions, although I will probably have to do it tonight, since I already have the 16 foot truck reserved for Wednesday to bring it to her house (it is in 6 sections...all in Oak plywood and Oak boards).
And yes, I know that I have to post pics after it is done, or else I really did not do it.
I appreciate all of your comments, and welcome them all. Thank you in advance.
Hinge type
