OT - to move all programs, data & settings from
Nort h of the Border
>an old computer to a new one: This program looks promising. Has anyone used it?
http://www.laplink.com/pcmover?ClickID=cfslqisxpklelzflvfvs74svnpenpalwxika#
Re: OT - to move all programs, data & settings fro *LINK*
steveotm
>A great program is True Image, you can get a 15 day trial here...
True Image free trial
Curly Smith
>I'm assuming that you have a new PC and you want to migrate your data and programs from the old PC without disturbing the new operating system. In other words, you're not trying to clone the old hard drive.
If that's the case then the Laplink program will work but it's probably not the best solution.
- First, it's expensive for a one-off installation. The simplest solution is to install the old hard drive in the new PC and then copy the data with a file manager. You can buy an IDE controller card for $15-$20 if your new PC needs it. Or, you can buy a network card for your old PC for $10 and transfer the data over the network.
- Second, if the operating systems are different then you have a very real risk of causing yourself hours of work. The Laplink program will copy the applications and their data to your new PC, copy any needed system files, and make any necessary changes to the registry to get the programs to work. If the two operating systems aren't identical then there's a chance you'll be copying incompatible files to your new PC and, consequently, that you new PC won't start when you're finished or that it will act strangely.
The best solution is to copy your data using any suitable method and then install the programs one at a time, test it, and then install the next program. There's no guarantee that all of your old programs will work on the new system and you're much better off if you can identify "problem programs" individually instead of wading through a list of 20 programs that might be problems.
However, if you want to use Laplink (and it does work fine most of the time) then:
- Go to your PC manufacturers website and download all of the drivers for your PC. Expand the files and burn to a CD.
- Make sure that you know how to boot to the last known good configuration, if applicable
- Make sure that you know how to reach the Recovery Consol, if applicable
- Make sure that you have your operating system reinstallation disk available
- Make sure that you have an alternate means of reaching the internet
- Install the Laplink Software
- Set a System Restore Point
- Migrate the programs and hope for the best
Re: OT - Thanks to both. Appreciate that.
North of the Border
Dan Donaldson
>Not only what you said, but the only way to copy running versions from one PC to another would be to copy the applicable registry entries to the new machine. If the operating systems are different, this could be a disaster waiting to happen. This is not to mention the fact that there is probably a lot of junk in the old registry and copying it to the new machine will just transfer any issues. Much better to just copy the data as suggested and reinstall everything cleanly.
