Re: OT _ Transfer of recorded TV programs
Bill Neff
>There are a couple of ways that I do this at work (there are more than likely tons of others, but these work for me). To copy from disc to disc I use Roxio Easy Media Creator's Disc copier (I have an older version 8). Just put the original disc in the dvd player & a blank in the burner & hit copy. There are shareware programs that will work at a lower cost (I'd look but since I'm at work those sites are blocked.) Google: Shareware dvd copying software.
To copy the video to your hard drive, I'll share a secret that was passed onto me by one of my "geek" genius buddies. This is for Windows, MAC might be similar but since I don't have a Mac I can't say for sure. Put the recorded disc into the drive, open Windows Explorer and locate the dvd drive with the disc. Right click on the icon and select either "Open" or "Explore". There will be 2 folders - Audio-TS & Video-TS. Double click the Video-TS folder to open it. You'll see a list of files (make sure you can see the file sizes by selecting View - Details in the upper menu. The file you want is usually the largest VOB file. Drag it to a folder on your hard drive. When it's copied over change the extension from VOB to MPG. It's now an Mpeg file and can be viewed in Quicktime or Windows Media player. Since on each disc the file will be named VTS_01_1.VOB or VTS_01_2.VOB & so one for each video file,If you copy several discs to your hard drive you might want to change the file name to something more useful to you like "Woodturning episode 1.mpg".
I hope this is helpful.
