Router Speed
Tom Rex in TX
>I'm running a 1/2" dovetail bit 1/2" deep in walnut.
What speed should I run my router?
Router Speed
Tom Rex in TX
Re: Router Speed
Kneale Brownson..Awaiting return to CO snows
>How about running a straight bit first? Half by Half is a lot of hardwood to be removing in one swipe.
Re: Router Speed
Norh of the Border
>You didn't say what kind of wood. Some softwoods like pine are easy to route. In general, I'd say 16,000 or so but not over 18,000 rpm. As suggested by another poster, it's easier on your bit to route the joint with a straight bit first.
It's Walnut. 16,000 rpm or so shuold be fine.
Norh of the Border
Re: Router Speed
Fred Davis
>Using a Keller jig , I just finished 12 drawers dovetailed all around and the 1/2 " x 1/2" is a pretty standard cut that a good router like a Bosch VS has no trouble with one pass cutting.
The wood was Pecan which is considerable harder then Walnut, while the router has a thumbwheel to adjust the speed.
I have learned long ago to listen to the tool while it is running and if it lugs , your running to slow , fast enough to hear no reduction in cutter speed while under load is about right.
FredD
Re: Router Speed
del schisler
>Don't cut or do in 1 pass You can go full speed But Not in 1 pass Take a little off at a time Their should be no problum To slow and you may get burn When you get almost to the 1/2" Take the last pass If any burn is their This should get rid of it
Re: Router Speed
del schisler
that was in the post
How do you take...
>smaller bites with a dovetail bit?
Miss read post I know better
del schisler
>you don't I miss read i thought a 1/2" round over I don't know where in the hell i got that from I just got back from 10 day's va I have 5 routers and do dovetale's all the time Only speed can be changes I use mine at the fastest and no trouble It is a A10 Box Makers Dovetail Jig - Gifkins Work's very well
