Dining Table
Dining Table
Dining Table
Bill Tindall, E.TN
>Finally nearly done. Still need to install extension slides. I thought this would be a good place to get its picture. Didn't realize the brick reflection would obscure the top.
Re: Dining Table
PS finish
Bill Tindall, E.TN
>Bottom is Benjamin Moore alkyd varnish and top is Sherwin William polyurethane varnish. Both sprayed. I like urethane for a top as it is very durable.
Re: Dining Table
more PS... the stain
Bill Tindall, E.TN
>The stain is ancient (over 30 years old) Sherwin William cherry mineral pigment stain. I am extending it all I can as I only have a pint left. I put it on like shellac with a rubber. This technique controls the "take" of the stain on the wood. An ounce did the whole table.
It is still my favorite cherry color. Someday I will have to formulate my own replacement from the Lee Valley pigments.
Re: Dining Table
Re: Dining Table
>Nice, clean design. I like what you did in bookmatching the apron. Were you able to do that on the other side, too?
Re: Dining Table
Re: Dining Table
>Good Evening Bill,
Outstanding table, color and finish. Thanks for posting. I'd be proud if mine turned out nearly as well. I bet your daughter is pleased!
George
Re: Dining Table
Re:Love the top shine...
DaleLenz
>did you buff it out with rubbing compound and power buffer? Also, how long did you let the poly cure? Good job. Dale
Re: Dining Table
I feel like your straight man here...
Dan Mitchell
>but you say "I put it on like shellac with a rubber". What's a rubber, & what technique are you referring to?
TIA
Dan
Re: Dining Table
Really nice job, Bill
Bruce, a MN Galoot
>Like Bill H, I like the matching on the aprons. What kind of sliders do you use to extend it?
Bruce
Re: Dining Table
Stain application technique
Bill Tindall, E.TN
>Wrap up a ball of cotton, linen, or sheep wool in another cloth and tie off the top of the wrap like a sack/poke of grain/coins, except the whole thing is the size of a golf ball. Dip and rub. I can do a picture later is this is not clear.
Re: Dining Table
Re: Dining Table
Martin from Texas
>Very nice, Bill.
Did you use plans, or make it up yourself?
I like the size, and it looks like you are planning to put in leaves, is that correct?
Is that a Brian Bogg's chair, or did you use plans for that as well?
Excellent job on the finish!
Thanks for posting,
Martin
Re: Dining Table
I see what you mean, thanks
Dan Mitchell
Re: Dining Table
answers
Bill Tindall, E.TN
>Did you use plans, or make it up yourself? Daughter designed it.
I like the size, and it looks like you are planning to put in leaves, is that correct? Correct one 18" and one 12" as per daughter instructions
Is that a Brian Bogg's chair No
Excellent job on the finish! thank you. I take much pride in my finishing
Thanks for posting,
Re: Dining Table
extension mechanism
Bill Tindall, E.TN
>I fabricated extension slides from Accuride drawer slides and some 1 1/2 x 3" oak pieces.
Re: Dining Table
Thanks!
Martin from Texas
