plywood blade recommendations
Kelly Anderson
>I will be starting a new project in the next week or two that involves plywood. I generally use my Woodworker II for just about every thing but was thinking that I would like a good plywood blade to help avoid chipping out the plywood. What blade do you use for plywood and how do you like it? Which blade would you recommend for plywood? Thanks for your help
