Re: getting started
Jim Dillon
>Jonathan,
Welcome to Wood Central! I started with a Milwaukee corded electrical drill and an old Rockwell jigsaw, then moved into the big time and got a router, sliding compound miter saw, a drill press, a bandsaw, jointer, planer, and finally a table saw. That rough order was dictated by finances and happened over a five year period. While the table saw is incredibly versatile, and a must-have, the jointer and planer are indispensable for preparing your rough wood. But since you may be initially buying wood that has been surfaced and planed from your local Borg, a table saw, bandsaw, router, and drill press would serve you well.
Since money is tight, shop for sales on the brands that are generally recognized as good value for the money, such as Grizzley, Jet, Rigid etc. And if you are in a more metropolitan area, used tools might be an option - but you kinda gotta know what you are buying.
Fifteen years ago, when I started to build my shop, I found help from a chapter in a paperback book from Taunton Press called "The Small Wood Shop". The chapter "Setting up Shop" described advice by three well-known woodworking authors: Peter Korn, Michael Duginske, and Mario Rodriguez, and heavily influenced my thinking. A newer reference is "Setting Up Shop" by Sandor Nagyszalanczy. FWW (Fine Wood Workinjg magazine) had a recent article on settin up a shop for $5,000. That probably sounds like a lot of money, and it is, but the cost of tools, clamps etc. add up. I also found tremendous help by lurking on a now deceased woodworking forum "Badger Pond", and now learn new things every day from the experienced and generous folk at WoodCentral.
I have found woodworking to be a great hobby as many of the same tools you will need, are also very, very useful for home improvement projects - something you might find attractive as you settle into your new home.
Hope this helps a little, and be sure to ask more questions as time goes by.
Jim
