OT Furnace/Duct design Questions
>I am working on a house for my cousin. I am thinking of doing the duct install myself. Is there a website similar to Wood Central where I can get advice and Details?
Like what size furnace would I need and what size would the ducts be?
Re: OT Furnace/Duct design Questions
John Veerkamp, Western Mo
>Barry,
there are sites out there, I don't know the name but a google search for furnace sizing ought to turn up some help.
John
Re: Furnace/Duct design
>Barry,
Not-fa-nuthin', but I strongly urge you to have the system designed by a well-trained tech or ME, preferably using a CAD program, with full specs on the structure. I've seen any number of systems put in by contractors who know "A-B-C" but have no clue that "R-S-T" and the other letters even exist. The results are inefficient systems, either under sized or way over sized, that don't function properly, can't be balanced, are costly to run, and are objects of derision by the homeowner.
I bought a "custom built" house, but the HVAC is an abortion. In the first year I took down and reset all the main ductwork in the basement, but I couldn't have the system redesigned without taking down a whole lot of sh**trock. I was able to reduce energy use by about 15%, but it's still a cobbled system full of compromises.
Richard Krieger
>FWIW Sizing a furnace and A/C accurately is based on something called a "heat loss" (heating) and "heat gain" (cooling) study. It takes into account things like window type and sizes, wall and ceiling R-values, which way house faces, number of doors, type of basement, etc, etc,etc. There are computer programs out there that all you do is plug in your numbers. It will give you the BTU furnace and A/C size. From that point, the ductwork will be designed based on physical dimensions of your home (how long runs are,etc.) Duct sizing is CRITICAL to maintain sufficient air flow to all outlets. Suggest getting a "pro" to do this for you and ask for a computerized print out of the two studies. This is a VERY common process for HVAC professionals to use.
