A55 Smoothing Plane
advice on planer head
david in indy
>I have a Delta 15" planer that has worked fine until recently. Fortunately it's still under the 5 year warranty (actually expired today) and the authorized Delta repair shop has come out and inspected it and advised me they will be replacing the entire cutting head, motor and v-belts - which is great. I had been considering replacing the head with a Byrd Shelix as I have with my jointer - but I found the propsect of the planer change out too daunting. Anyway, I got the Byrd head and after initially telling me they would install it instead of the Delta replacement, they changed their mind. Said they couldn't guarantee the completeion of the warranty work - which I can understand - to a point. The Byrd head should work perfectly fine and not cause any problems itself. The tech who is coming out to do the work says he has never worked on this machine - this is the Dewalt repair center that has now taken on Delta. My choices are: (1) send the Byrd head back and live with blade-changing; (2) take the planer apart myself and replace the head right after they put it back together; or (3) see if I can't persuade the tech in person to let me put the head in while it's apart. The problem with (2) or (3) is I lose the warranty on the warranty work. Given the lack of the tech's experience, I may well need it to make sure he does the job correctly. Any other thoughts?
Re: advice on planer head
>How long is the warranty for the repair? Typically they aren't very long.
I can tell you from experience that the Byrd head is a very nice upgrade. You have gotten over the hard part....paying for it! I'd be tempted to ask the technician to install the Shelix for you. I think you would enjoy the difference.
Just 2 cents
Tom
Kneale Brownson..Awaiting return to CO snows
>As Tom says, your guarantee on the warranty work may be relatively short.
I'd watch the guy disassemble and reassemble (maybe even take pix or videotape) and then install the Byrd myself.
Fred Davis
>Try this, Tell the Tech that you really would rather have the Shellix head installed , then a relatively short warranty from Delta.
Tell him you really appreciate the response for the repair and ask him if he would like to treat the job as a side job for him, on his time and your dime.
This is better then trying something you haven't before and the Shellix head must have a warranty of their own to boot.
Kinda hard to believe he would be inflexible enough not to respond to that offer.
But you will never know if you don't try.
FredD
david in indy
>Thanks for the responses.
