Fantastically terrifying shop experience
A.J. Hamler
A.J. Hamler
>I don't normally mention or share topics from my Woodshop News blogs, but I thought you all might find my most recent one frighteningly interesting. This is what happened to me in the shop last night. I titled this blog "Afraid of the dark." Read on...
"We�ve all had scares in the shop with machinery. I had one last evening that was not only terrifying in a woodworking sense, but the most terrifying I think I�ve ever had.
"Although I work with machinery easily and often, I have a respectful fear of it. This is a healthy thing, and I hope you feel the same way. There�s no machine I respect more than my table saw, and when I�m using it I focus 100% on the tool and what I�m doing. I check everything � my stance, my fingers, clearances and obstructions, feed path, my fingers, fence, the stock and, oh yeah, my fingers. I leave nothing to chance. Ever. But yesterday, chance had other ideas.
"I was ripping stock for a new hardware storage center, for which I needed seven workpieces cut to the same width. I was cutting them one after another, and was on the fourth one when it happened. While feeding the stock through the saw, at the exact moment when my hands came the closest they would come to that blade, the power went off.
"My garage shop has no windows, the door was down, and even the door to the house was closed. The result was that at the exact moment my hands were closest to a spinning saw blade, my shop was instantly plunged into total darkness. No power, no lights, not even those little dots of red or green from a battery charger to give you some reference of place or position. Nothing at all.
"Absolute terror went through me. I was in complete control a moment earlier, but in the pitch blackness I found that I suddenly couldn�t remember exactly where my hands were in relation to the blade � which, although now spinning down, was still spinning and cutting the stock.
"Several possible actions went through my mind: Let go and step to the right, or pull the stock backward out of the blade, or maybe nudge the stock a quarter inch forward to add load to the blade to stop it more quickly, and a hundred other things all in the space of a half second. Instead, I did nothing at all. I froze, held my breath, and didn�t move a muscle as I waited for the blade to take what seemed minutes to spin down to a stop. (In reality, only a couple seconds.)
"The blade stopped and I let go. I was taking a few more seconds to orient myself when I had the presence of mind to reach out in the dark and slap the big red stop button on the saw. A minute or two later, the lights popped back on.
"With everything over, now was when the cold sweat and a sudden case of shivers broke out. I left the shop and took a slow walk around the house resetting all the clocks that were now flashing. By the time I was finished, calm had returned and I headed back to the shop to shut it down for the day � didn�t really feel much like working.
"In my June 30th blog, I talked about expecting the unexpected. Well, I sure never expected this, but still managed to keep a presence of mind during what happened.
"And as a result, nothing came of this potentially dangerous occurrence but a good story to tell."
A.J.
Re: Fantastically terrifying shop experience
I had a very similar experience
Neal in San Jose
>Here in earthquake country, sudden and unexpected power outages are not common, but not unknown, either. I was doing exactly what you were, A.J. when the power went out, and besides standing in the dark with my hands next to a spinning blade, I could feel the floor (and everything else) moving. NOT FUN!
I purchased several inexpensive battery operated emergency lights and plugged them in to a couple of the outlets nearest my work area. None of the outlets were orientated so the lights would shine directly on the table saw or my work bench, so I ran two extension cords and jury rigged a couple of holders for the lights to shine where I really need the light. There have been two more outages while I was working (luckily not using power tools either time) and I was able to confirm that the lights do exactly what I want; provide enough light that I can see where my hands are while everything spins to a stop.
This was such a good idea that SWMBO had me add one in the kitchen, one in the bathroom and one in the master bedroom.
Fred Davis
>A.J.
, There s nothing like a good scare to make a lasting impression.
The event you described is one of the reasons a Magnetic start switch on your saws and shapers and lathes , really are a good idea , well worth the few extra bucks for one .
FredD
Ken Oakley-Sunny St. Cloud, Fla.
>If your machine is equipped with a magnetic switch it could not have restarted when power came back.
WHEW !
steve mackay
Wow, AJ
>You got me terrified just reading about your incident. I'm glad you had the presence of mind to hold still until the saw wound down. Emergency lighting is sounding like a fine idea after hearing your experience.
Thanks for posting.
>A.J.,
Too bad you don't have a Saw Stop. If you did you could use a push stick made out of hot dogs and be perfectly safe in the dark. ;-)
Tom
Kneale Brownson..Awaiting return to CO snows
>I've thought about it going dark because my shop is in the far end of the barn, away from the door, and the barn is always full of obstacles I'd have to feel my way around to get to light.
One of my thoughts years ago was I wouldn't want to be in the spot where you found yourself, with hands close to a spinning blade. So I never let my hands get close to a spinning blade. I use push sticks and featherboards when ripping.
Victor Parisian
>And what do you think activates the saw stop so fast? Could it be electrons?
Visions of a limp hot dog "push stick" trying to push a piece of 12/4 maple though the saw.
Lights go out in Houston on occasion for up to 14 days.
Victor in Hot and Humid Houston
Scares me just reading your story.
Victor Parisian
>I am kind of fond of all ten of my fingers and i like them where they are. sure makes typing easier.
Victor
>AJ It was almost worse for me. I was using a vacuum chuck to hold a moderate sized bowl to turn the bottom. Power went off, the room was totally dark and a bowl was now flying around the room bouncing off everything. Fortunately I think the tool rest kept it from flying my way.
Fred Davis
>Exactly
FredD
Push Stick! Push Stick! Push Stick!
charlie belden
>and a riving knife.
Thankfully the saw didn't come back on when the power came back on. Magnetic switches are really a great invention.
Gives new meaning to Think Fast!
I would've thought...
Bri in Mtl
>I would've thought that if it happened while pushing the stock through that the blade would've stopped almost instantly.
A.J. Hamler
Re: I had a very similar experience
A.J. Hamler
>Neal..
Shortly after posting, I had to go out to do some shopping. One of the first things I did was to buy a couple of those flashlights.
By the way, regarding those automatic flashlights, I agree with you when you see that they enable you to...
"...I can see where my hands are when everything spins to a stop."
Not sure how that applies in the bathroom and master bedroom though.
A.J.
A.J. Hamler
A.J. Hamler
>Absolutely correct, Fred, and an upgrade I'm considering.
A.J. Hamler
A.J. Hamler
>I never use a hot dog as pushstick; I use a baby-back rib.
A.J. Hamler
Re: I would've thought...
A.J. Hamler
>It probably would have if I'd have kept pushing. I froze immediately when the lights went out. A slight nudge of the stock into the blade would have stopped it more quickly, but I was loath to move a board into a blade I couldn't see.
A.J.
A.J. Hamler
Pushsticks
A.J. Hamler
>Several of you have mentioned pushsticks, and while I'm a great proponent of them -- I have, and use, several -- I don't believe they're always called for. YMMV.
A pushstick gives me the same amount of control over a piece of stock as my hand does. If the stock is too narrow to safely use my hand, I use the pushstick every time of course. But if there is enough room to safely use my hand to control the stock, I use my hand. I feel the increased control I have in those situations is a safer procedure for me than using the single-point-of-contact control that a pushstick has. Again, YMMV.
Now, if the same thing had happened while using a pushstick, I'm still not certain I'd have reacted any differently. A spinning blade in total darkness is still a spinning blade you can't see. And while a pushstick in that situation might have placed my hand further from the blade, the pushstick itself would still be close to the blade. Sure, the pushstick doesn't bleed if it contacts a spinning blade in the dark, but the resulting action of the stick hitting the blade could not only deflect my hand into it, but the stick itself could then become a dangerous missile.
A.J.
GalenV in Iowa
>I wonder if a commercial vacuum chuck has any warning about sudden lose of vaccum. Guess if the compressor is beyond their control it is use at your own risk.
But then I had a bowl wack me in the face shield when it was in a jumbo jaw with the rubber fingers to hold. Power did not put me in the dark but the impact just about turned my lights out.
After the stories guess I will get the battery backup light out of the junk drawer and use it in the shop. Shop is in the basement with no windows for backup lighting.
Galen
Re: Pushsticks
Don Evans
>I have not read the other responses so this may have been mentioned but I didn't see where in your check list you went through any mention of "hold downs" especially on the fence. You should always use these on a ripping action, one, two is better, on fence to hold wood down and one on side if the other miter slot is not covered by the wood, this one pushes toward the fence.
On pushsticks, there isn't just one, you should have several with different designs, each design for the particular job being done.
I also have lights in my shop that come on automatically when and if the power goes out.
Interesting that this is one situation that a "Sawstop" would be of no help!
Don
Re: Pushsticks
John in NM
>I find the use of two push sticks, one for each hand, much easier. The one in the left hand has a tapered end and a notch so that it acts as a splitter (its used behind the blade), and holds the piece both against the fence and down on the table. I usually use this stick even on pieces wider than 6" where I don't usually use the right hand pusher. I typically reserve feather boards for more specialized cuts - modifying molding or cutting coves for example. One should use hold downs where one is uncomfortable with control of the work piece, but I wouldn't go so far as to call a rip cut without them un-safe.
It sounds to me like AJ did the right things under the circumstances, its just that the circumstances were so unusual. My shop is currently in a basement, and as we often lose power for a few seconds during summer thunderstorms, I've specifically avoided using the table saw when I thought we might lose power. Power often comes back up in less than 30 seconds, so I wouldn't be inclined to try to slow the blade by continuing the cut as it'd be easier to control the piece if the blade had as much momentum as possible when the saw came back on (minus a magnetic switch in this case).
A.J. Hamler
Re: Pushsticks
A.J. Hamler
>You're right, SawStop would not have helped. But then, neither would hold-downs or pushsticks. Those are both great, but my particular issue was that my hands were in proximity to a spinning blade in the dark. While pushsticks and hold-downs might change that proximity, the fact remains that when the lights went out I could not remember exactly where that blade was in relation to any soft fleshy parts I wanted to preserve. That wouldn't have been changed by a pushstick or a hold-down.
By the way, you're correct in that there are different pushsticks for different tasks. If you re-read my pushstick post, you'll note I mentioned that I have (and use) several. No two are exactly alike as to design or purpose.
A.J.
Ned Bulken
>My shop is still in the 'temporary power' stage... (Extension cord from the house), and all of my tools and lights run from a central power strip. I generally am running only one tool and a flourescent light strip at any one time, but I've had occasion where a tool has popped the breaker on the strip, thankfully with similar results.
