Ash For Drawer Sides
Tom Rex in TX
>Is ash a good wood to use for drawer sides & back?
I usually use soft maple but Rockler in Mesquite has ash on sale.
Thanks,
T Rex
Re: Ash For Drawer Sides
Joe in a Cleveland Suburb
>I used it for all the drawer sides in my kitchen about 6 or so years ago. I thought it smelled horrible when milling it, but other than that, it worked out well. That said, I am not a huge fan of the look of it.
I used it because the guy I used to buy lumber from (who supplied Amish cabinet/furniture makers) sold a boat load of it to me for less than a buck a board foot. Plus he said they (the Amish) used it for that.
FWIW.
Ash is fine for this...
>... but I would recommend spraying some kind of sealer on it to plug up the pores and keep the wood from getting dirty-looking over time. Lacquer would be a good choice.
Ellis Walentine, Host
>I use poplar. But poplar is inexpensive for me (less than $2/board ft.). If the ash is cheap, go for it.
I personally don't like using any larger pored wood for interior drawer sides. I never feel that I've completed filled or packed the pores. But that is my personal preference.
Would Polyurethane Work?
Tom Rex in TX
Ditto on the poplar
Dan Mitchell
Sure, but...
>... I suggested lacquer because spraying is so much quicker than brushing, the material dries faster with less sag and more dust free, and there's less residual odor inside the cabinet. The point of the finish is simply to fill up the pores so dirt doesn't catch there. A diffuse porous wood like poplar or soft maple is preferred by many people for this reason, but I've used ash successfully as secondary drawer wood. Think of all the oak drawers you've seen in your day. The biggest trouble is that the grain is usually poorly matched, so the drawers look pretty chaotic.
I'd never use poly on drawers again
Dick Coers
>I used poly on a desk that I made for my son 25 years ago. I can still catch a slight odor when a drawer is opened. I only use shellac for drawers now.
Any oil-based varnish will have a residual odor
>I'm with you, Dick, but I don't know about waterborne polyurethane products. I suspect those are less objectionable.
depends on how drawer is mounted
Bill Tindall, E.TN
>If the drawer rides on wooden runners and drawer divider, as in period furniture, it makes better sense to use a soft wood for the drawer side and a hard wood for the runner. The idea here is that it is easier to fix a worn drawer side (plane it square and reglue on a strip to replace worn part) than it is to fix the worn parts the drawer rides on.
But, if the drawer is mounter on metal slides then it matters not what the drawer is made of. Ash looks very nice in this application. Strangely, there is little demand for it so it is a very cheap hardwood now. Years ago it tracked the price of cherry.
Re: Would Polyurethane Work?
Dave Bair, Eaton Rapids, MI
>Or try SealCoat shellac. I apply using a white foam roller followed by a soft nylon brush.
