How to make a Grizzly purr - Need advice *LINK*
Pete
>Ok, if you've been following our reluctant hero as he's anguished over a G1023 saw, here is the update. The tale continues, preceded by the usual pleading for more advice from the masters. "Please sir, may I have some more?"
Ok, I bought her for $275, and brought the girl home. I think she has good bones, but in need of some help. I've added pictures to show her rough parts. Please follow the link at the very bottom.
Here is a list of my issues
- Table rust - There is some light surface rust on the table. I'll follow someone's advice and use a green scrubby pad on a power sander, flooded with mineral spirits. Great idea. After that, I'll plate sand it with 220 thru 440 sandpaper backed by glass, and follow that with wax.
- Motor only runs with the power button held down - Per numerous suggestions, I will clean out the magnetic switch.
- Grease and lubing - The motor raises and tilts with ease, but with a little creaking. After cleaning;
** Should I use grease, paraffin, or oil?
- Power - The plug provided does not match the shape of the receptical. However, both are 220. The motor calls for 30 amps, and the breaker is 50 amps. Pictures are included.
** What do I do here? Is this just a 'shape' think that requires a new plug?
- Fence - Numerous problems here. I would rather not purchase another fence if I can avoid the expense. The sides I am not worried about. Phenolic plywood will replace these chewed up sides. However, the clamp is missing the part that presses against the rail.
** Is there a way to fix this? Are there parts I can find?
- Fence #2 - The fence does not slide well at all. There appears to be some gunk built up along the rails. I can clean it off along with the table top, but
** how to lubricate? Wax, oil, grease?
- Fence #3 - It appears that the bolt holding the rail to the table are to long and are interfering with the fence. I will purchase shorter bolts.
** does this make sense?
Thanks again, your advice is really appreciated.
Pictures with captions are located here. Clicking on each will expand them. Once expanded you can see them full-screen, or zoom
Pete
PLEASE USE THIS LINK TO THE PICTURES
Re: How to make a Grizzly purr - Need advice *LINK*
Robby Wright
>Contact Grizzly and see if they have the parts to repair the fence. It looks like a decent clone of a T-square fence and probably could be restored.
- I would use either lithium grease or a teflon based lubricant that doesn't contain silicone. The teflon based lube is dry and won't attract dust.
- The first plug picture isn't supposed to be a 220V plug. That is a NEMA 5-15 recepticle and is supposed to be 110Volts. It it is 220 Volts, you have a serious safety issue.
Your new motor is a 30 amp motor. The heavy duty plug you show is a standard dryer plug and you stated that it is 50 amps. Although you can change the connector on your saw and plug into it, you have the problem of components rated for 30 amps (cord, etc) plugged into a circuit protected by a 50 amp breaker. The easy solution is to change the breaker and outlet to 30 amp units. The wiring is plenty heavy enough.
** how to lubricate fence? Wax, oil, grease?
- Wax
- I would just trim the bolts with a grinder.
Electrical
Randy Johnson Connersville IN
>The receptacle you have was probably for a welder or maybe an electric range. The wire will probably be overkill. (#6 or #8 copper or aluminum) I say probably, because I have seen some really bad electrical jobs. One guy was running a 225 amp welder on #12 romex. He only got away with it because he never used the upper ranges. Anyway.... More importantly, the breaker is going to be too big. Using it will be something akin to a penny in the fusebox. If it were me, I would start new from the panel and install the right size wire. The problem with what you have is that it won't fit on a properly sized receptacle. It also won't fit on the new breaker that you HAVE to get.
When you buy the new receptacle and breaker, just get a male plug to match.
I haven't followed the entire saga so maybe I missed something. Is the saw a 5 hp? If not, I question the 30 amp rating. I have a BUNCH of single phase 3 hp motors in my shop and all of them run just fine on 20 amp circuits.
Ok, is this right?
Pete
>First, thanks for the advice.
Yes, it is a 3hp Grizzly G1023.
The previous owner was a steamfitter, and it was used for a welder. Give his expertise, I assume that it is the correct gauge wire. Re-running the wire would be very difficult, but I will pull apart the receptical and check.
Ok, if I understand what you are saying (and assuming the wire is fine), I need to do the following:
- Replace the 50amp breaker with a 30amp at the panel
- Purchase a plug to match the receptical.
Is that correct?
Wow! Glad to read you got it at the $275.00 price
Eddie Pacheco; Antioch, Ca.
>On the rust.
Don't kill yourself trying to make the top look like a Powermatic's. It won't happen. Get it to where there's only some dark places here and here. I just redid a Delta contractor saw and could not remove the ring from a cup or beer bottle. I think your table may end up looking like a severe case of freckles. It's ok. After the wet sanding you can do a rubbing compound or polishing compound (or both) treatment. Then you can follow this with Minwax or a good car wax. Your top will be freckled, but slick.
Power Button; Not sure here. Take it apart and have a look.
Creaking sounds; If the lock knobs are adjusted out it's probably just some oxidation in the shaft. Oil and usage will make that go away. That trunnion assembly is cast iron too, so it's safe to say that the bores for the tilt and lift shafts got oxidized too. Flush them with oil to get the bigger particles of oxide out.
The Plug and outlet; I use the connectors from either Hubble or Pass & Seymour (Home Depot) The numbers are; NEMA 10-30R for the receptacle and NEMA 10-30P for the plug. Are you sure 30 amps? I have a Delta Rockwell that is 3HP and 20 amp connectors work well. Real well. I went with the 20 amp because they were locking type.
On the metal plug for the fence, I suggest you check the Grizzly site for their parts catalog. Grizzly has a loyal following and a lot of that is because of their great service after the sale.
Good luck, Pete. It will still be a bargain even after all of the elbow grease.
Re: Ok, is this right?
>Yes, but the existing wire, assuming the right size was used for 50 amps, is not going to fit the new breaker or the recptacle. In woodworking terms, it will be like trying to fit a 1/2" dowel into a 3/8" hole.
You have three options. The most desireable is new wire the proper size. Choice two, a very distant second, is to snip a few strands off the ends of what is already there so it will fit. Choice three is a splice to smaller wire with split bolts. (NOT wire nuts)
I still question the 30 amp rating. The table in the book I have handy lists FULL LOAD for a single phase 3 hp at 17 amps. Unless you plan on regular ripping of 8/4 oak, a 220/20 amp breaker should be fine. That leaves you with one more small problem. The receptacle you pictured is a surface mount. When you remove it you will have to mount a new box for the new receptacle. Because of the size of the existing wire (if you decide to use it) the new box should be a 4X4, preferably a deep one. I would buy a metal cover. The new receptacle will mount on the cover instead of the box itself. The clamp that holds the wire is built in on surface mount receptacles so you will also need to buy one of those for the new box. A 3/4 " clamp should work for the wire that's there. If you run new, a 1/2" will work.
Andy Lincoln,in Dearborn,MI
>Pete,
Congrats on the new piece of big iron.I am sure it will be up and running well in no time.
As far as the fence bolts go can you remove the square tube and put the bolts in from the front?Through the angle iron into the table? That is how a Biesmeyer fence is mounted,mine is mounted with countersunk flat head machine bolts.
Andy
Ben Ragusa, S Jersey
>Congratulations on a great find. Looks like it will restore just fine. One thing I would do is call Grizzly and request the owners manual and parts list (prepare yourself with the model and serial numbers first). It might help to explain why those bolts are sticking out (could just be assembled wrong). Good luck
Purring Grizzly - cheap advice
Lee Schierer - McKean, PA
>The bolts that are sticking out can be cut flush the thread sticking out in the air isn't doing anything. Or take a measurement of how far they stick out and go to the local hardware or bolt store and buy some that are a bit shorter and replace all the bolts.
I would clean up the fence, wax it and if it still doesn't slide easily, buy some UHMW Polyethylene tape from some place like McMaster Carr it comes .0045, .0065 or .0115 thick. Apply it to the underside of your fence clamp assmebly so it will touch the fence rail. They also sell teflon tape, but it will not last nearly as long.
Lee
Excellent point. I'll look at Lowes for the bolts
Pete
Great call on the fence plug
Pete
>$29, in stock, shipping today. Nice call, thanks.
Griz-world
Rod Peterson -- Ormond Beach
>If I remember correctly, there were several threads a few years ago about Grizzly recommending 30A circuits for their 3HP saws. The cognoscenti know a 3HP motor will be adequately (and safely) served by a 240V/20A circuit, but there were a lot of Chicken-Little hand wringers who worried that using a 20 amp circuit might void the warranty if the tilt knob broke or something.
Rod
Re: Griz-world
Fred Davis
>If Griz was recommending 30 Amp. service for their TS , it was probably for the same reason I had to install a 25 amp breaker for my 9 year year old Powermatic 66 from the getgo .
My Electrician said the newer motors were drawing as much as 27 -28 amps momentarily on startup which kicks the 20 amp breaker , like the one my 1974 model Unisaw runs on perfectly.
Since we couldn't get a time delay breaker in twenty amp size for that brand box, we used the 25 amp standard one with no more problems .
Another thing about the newer motors which I find to be a PITA on the feed motor on a Delta 18/36 drum sander is the Thermal overload protection is set so low , that you really have to pay attention to the load on the sander or you get to wait a few minutes for the motor temp to drop.
So it seems to me like the motor is under sized for the job , but then I never designed tools. ;-))
FredD
Alan in Little Washington (NC)
>There is a bit of erroneous electrical info in this thread!:
"- The first plug picture isn't supposed to be a 220V plug. That is a NEMA 5-15 recepticle and is supposed to be 110Volts. It it is 220 Volts, you have a serious safety issue."
No issue at all! That receptacle is a NEMA 6-50 (and labeled so) and therefore rated at 250V/50 Amps! See link for NEMA designations and plug configurations.
"Your new motor is a 30 amp motor. The heavy duty plug you show is a standard dryer plug and you stated that it is 50 amps. Although you can change the connector on your saw and plug into it, you have the problem of components rated for 30 amps (cord, etc) plugged into a circuit protected by a 50 amp breaker."
This is a typical misconception. There is absolutely no "problem" at all doing this. The breaker protects the house wiring NOT the equipment. Is there a problem plugging a little 2 amp table lamp into a household outlet typically rated at 15 or 20 amps? No! Same situation here!
NEMA plug configurations
Re: Electrical *LINK*
>See my post above. If the circuit is wired and fused for 50 Amps then the NEMA 6-50 receptacle shown is appropriate. I assume the pic is of an installed receptacle in the OP's shop/garage. It may have been for a welder, electric clothes drier, etc.
"Anyway.... More importantly, the breaker is going to be too big. Using it will be something akin to a penny in the fusebox. If it were me, I would start new from the panel and install the right size wire. The problem with what you have is that it won't fit on a properly sized receptacle. It also won't fit on the new breaker that you HAVE to get."
As I said in the prior post, there is absolutely nothing wrong with running his saw on that outlet!!!! The breaker protects the house wiring, NOT the tool!!!!!! It has been this way forever and will not change no matter how many times people say otherwise. All the OP needs to do is match the receptacle with the appropriate plug. Again, it is no different than running a 6W nite light which draws a mere .05 amps on a standard household 15 or 20 Amp outlet!!!
Come on guys!!!
Re: Griz-world
>A much better solution to the problem you describe is to add a fused disconnect between the main panel and the motor. You can always find time delay fuses. If you use an oversized breaker you are taking a chance.
The problem of heavy start-up loads really gets noticable in agricultural and industrial applications. That's why they still make fused disconnects.
Re: Griz-world
Fred Davis
>The solution you describe while workable would be overkill in this particular situation.
Both the Master Electrician and I , remembered the time about 1980 or so when hardware stores and Electrical supplies and building departments were notified that the AWG requirement was going to change on the first if January the next year.
Essentially what had been proposed was upgrading load limits to the next wire size , so for instance a 12AWG would be rated for thirty amps.
For reasons I have forgotten , this did not come about , but the science remains the same.
There is no risk running a 25 amp breaker on a #12 AWG dedicated line to a 240V motor , running intermittently .
The up graded breaker has worked fine for nine years and I suspect as long as I will need it.
However, I am not advocating in any real sense that people run rip cord to their equipment (saw a sheet metal man do to a Jenn-Aire range), I do recommend the use of a real Electrician when the work has progressed much beyond lamp and battery changing.
FredD
Re: Griz-world
Fred Davis
Re: Electrical
Pete
>Morning all,
Ok, current wiring status.
- Went to Lowes. Master electrician agrees with you. Fuses are for wiring, not appliances / tools. He also said the following. If the table saw jams, it is gonna pull a helluva lot more than the 50amp breaker currently installed.
- That all being the case, I purchased a 30amp breaker anyway. I'll drop it in when I get a chance.
Also - The saw will currently ony run when the power button held in. I'll be taking the switch to the electrical folks late today.
