Table nearly done
Table nearly done
Table nearly done
Bill Tindall, E.TN
>Got the legs finished and just need to stain and varnish the top. Table is daughter's wedding present.
Re: Table nearly done
>That is very nice, Bill.
I can see how massive the upper legs are, and presume you've used mortise and tenons. Those corner blocks should make it rock solid. I'd like to see it all together once you have the finish applied.
I hope you have had much better luck with your daughter's table than I have had with my #2 daughter's table. The first top warped badly in the lousey humidity, and I had to recycle most of those planks. The second iteration came from a different hardwood source but still moved quite a bit. Eventually it could be used as intended. I can't remember when we had so much humidity and rain. And, I can't remember having a simple project which fought me so hard and for so long.
George
Lee Schierer - McKean, PA
>I hate to tell you this but it is a really nice looking set of legs, but you put the skirt on teh bottom and the top is a bit thin.
Lee
Looks like U know bout the upside down spray trick
Frank in Forest Hill
keeping the top flat
Bill Tindall, E.TN
>Indeed, keeping the top and leaves flat is a major concern. In a typical table this is less a concern as the top can be pulled flat to the frame. But an extension table frame is less rigid so the top needs to stay flat, as do the leaves.
I resawed the 1 1/8" thick top from some thoroughly equilibrated 8/4 and let it sit for a few days before flattening and gluing. After these parts were laid up I have kept these parts at constant humidity and stacked with air access to all sides. I have started to finish the top and once a coat of varnish is on each side these parts will be more stable. But one doesn't breath easily til the top is fastened to the frame and it sits in daughter's house.
