O.T. Dehumidifier Sizing
Richard Krieger
>Long time....No post....
I recently purchased a Frid.... dehumidifier for our basement. Home is a 9 year old 2,300 sq.ft. ranch with a 2/3 walkout (above grade) basement. There is NOT a severe humidity or moisture problem. We just wanted to keep basement area "fresh" during the summer. Since installing the unit, it "short cycles". No matter what humidity level is chosen, unit will run for about 10-20 seconds, then shut off. Re-start, then run for about 5 minutes. Will "short cycle" again for 2-4 more times, then run for about 5 minutes. Unit is installed with a continuous drain hose. Adjusting the humidity level or fan speed does not change symptoms. If unit was adjusted to 55% level, then immediately turned up to 70%, within 10 minutes, the short-cycling starts in again. Current humidity level is at 65 % with fan speed on LOW. I suspect that the humidistat is defective. It is a 50 pint size. Looking at "on-line" sizing charts, for a 2,500 sq.ft. home with anywhere from a mild to severe moisture problem, anywhere from a 30-45 pint unit is recommended. Why is it "short cycling"????
Any help greatly appreciated...
RLK
Re: O.T. Dehumidifier Sizing
Jesper, Denmark
Re: Nothing to do with the sizing......
Jesper, Denmark
>Either the hygrometer is faulty, the coil is freezing up (unlikely) or the refrigerant has leaked.
Take it back and get a good one as replacement.
A few minutes of running does not really change the Relative Humidity much, it takes a long time and happens slowly. There is a LOT of water in yur walls, floor etc., so do not expect quick changes in RH.
Sampling?
>The "short cycling" your describing sounds like an energy saver circuit. I have a Fedders/Hampton Bay unit that does something similar. It was explained to me that the short fan runs are to give the humidistat a "taste" of the air to decide whether to run the full compressor, and also helps prevent the coils from freezing up. I've replaced the humidistat several times over the years because of shop dust. Cycling has remained the same. I also have a Danby which runs the fan continuously and then kicks in the compressor when needed.
As far as size goes, for comparison, I run two 50-pint units in my 40x40 basement to keep the shop and office dry. I have no wet walls or water problems, but the two units will each be emptied 2-3 times a day in the summer months so I'm taking between 15 and 20 gallons of water out of the air each day.
SWMBO uses the condensate as plant water.
Re: Sampling?
chuckbeck in cent il
>You also do not mention the temperature of your basement. If it is 75deg it will cycle differently than if it is 65deg.
Re: Sampling?
Richard Krieger
>Thanks....Basement temp runs about 65-70 degrees when outside ambient is in the high 70's or low 80's. We have a tankless water heater, so we don't get much "heating" effect from an old water heater tank and burner.
Don't know...................Sent an email to Frigidaire and am waiting for a response. I still think something is wrong. As another poster said, humidity doesn't change that quick to run 15-20 minutes then shut off.
Thanks again.
