REAL MILK PAINT
OT - Advise/Suggestion On Security System
Doug Ring
>We are looking at having a residential security system installed, and would like to get any advise or suggestions on what works and what to avoid. Typical suburban setting, two story house, and primary concern is robbery while we are away from home. At this time, getting a dog is not an option.
We have received quotes from Brinks, ADT, and two other smaller local firms - harware-wise, all are very similar in price and capability.
TIA,
Doug in San Diego
Re: OT - Advise/Suggestion On Security System
>Large dog and Smith and Wesson.
Seriously though, I've had ADT. They've worked reasonably well. The thing to make sure of is that you buy the entire installation (control panel, window and door sensors, glass break detectors, motion sensors) and then pay for the monitoring of the system. That way you have an "out". If you aren't happy, you can go with another service.
My $0.02.
Thomas S Stockton------WebKitFormBoundaryRU4sWQOIA
>The only problem with advertising you have guns in the house is that it attracts thieves instead of deters them. A determined thief will be in and out of your house with a handful of guns in a matter of minutes, unless you have them locked up.
Tom
Interesting revelation from my local LEO
Ed Beck
>(Watching too much NCIS)
I called my local law enforcement agency (the city Police) and they said that all the alarm companies were pretty much the same.
But the REALLY INTERESTING THING was that if your alarm goes off, the alarm company monitoring the system first calls you to see if you're home or not, and then they call the local police department.
When the local LEO gets the call, it goes straight to the BOTTOM of their list. Why? Because of the number of false alarms that come in from home security systems.
Now what goes to the top of the list is when the home owner calls the LEO and says something like "I have a perimeter and internal motion detector alarm, and no one is supposed to be home". That gets their attention and gets you pushed way up in triage.
This is why I had my alarm company give me the ability to program alerts to go straight to me (as well as them) so I could be on the phone finding out what's going on, and that annoying call waiting is them trying to tell me that an alarm is going off.
Re: Interesting revelation from my local LEO
Richard Krieger
>FWIW My alarm monitoring company uses a "call list" that I fill out when monitoring starts. It lists my preferences in a priority order of whom I want called. List is "over-ridden" IF a "PANIC" code is received (hostage situation or forced dis-arm) or if a fire signal is received.
My suggestion: Either do your own (hard-wired) and/or use alarm company. I am sure there are several "privately" owned and local firms that are more "home-town friendly" than a national chain. With you owning your own equipment (house wiring/motion sensors and door switches), as has been said before, you have a lot of flexibility. I can pay by the month or save some $$ and pay annually. Averages about $21.00 a month. Our local LEO does NOT put residential alarms at the bottom of a list. However, if false alarms persist, you may be "charged" for a police run.
Try to stay away from lots of bell/whistles. Use a high quality infrared motion sensor indoors and perhaps a microwave sensor in garages or outdoors if needed. I tied my outside flood lights using a remote relay to come on with alarm. Suggest "bugging" all exit doors and keeping only one on a "delay" for entry/exit. Talk over your life styles with alarm people to come up with a system that works best for your family and style. They are NOT all the same. You can put tons of $$$ into a system or you can just have a good basic system. The concept of an alarm system is to 1- Give a sense of security for family members while at home, 2- Create NOISE and awareness in the event of a forced entry when you are not at home and in my case, 3- An alarm in case of smoke or fire.
Good luck.
Ken Bellock (Houston, TX)
>After my cubemate at work was robbed at gunpoint in their home here in Houston, they took what they learned from the incident and put that into their new security system. First thing they asked for was a "beacon light" for the house. When your alarm goes off it flashes lights in front of the house so that cops can easily locate your place even at 3am when house numbers are not lit up. After the pros left their house with the phone lines cut, they ran to their neighbors house and called the cops. It took over an hour for them to get to the house, and the cops said it was because they were driving up and down the streets trying to read the house numbers in the dark. It cost me $50 to add this to my system.
I also talked to the installer when they were putting my system in, and he said here in houston, the pros have a system, and are not scared away by security systems. They cut out the glass from a window in your master bedroom if it's on the first floor, to avoid window open sensors and glass breaks. They stay out of the living room where a motion sensor could be, and just raid your closet and bedroom for cash, guns, and sparkleys. He said they even usually leave computers, they want small and expensive, or guns.
Another person in my office had their house broken into exactly in this way here in houston. Came home and found a nice neatly cut pane of glass sitting up against the house by the master bedroom window, and everything in that room turned upside down.
I still have my system monitored to give the wife a warm fuzzy, but will be installing cameras in the house and around the perimiter, and will be putting up signs saying "video monitoring" or some such thing. I'm guessing that will help more than the security system. I hear that is what ended up making it possible for the authorities to catch the killers of that couple in FL with all the adopted kids.
Ken
