Shelving cleats sticking to wall
A.J. Hamler
>While in the process of updating my shop, I removed several sets of shelving to either move or replace with something else. The shelves are plain pine boards attached to cleats on the underside, which are in turn screwed to wall studs. No other adhesives used.
The thing of it is, is that when I took down the shelves and then unscrewed the cleats, they were stuck fast to the wall. Pulling them off also pulled of paint and numerous smallish sections of the drywall paper (although not all the way down to the plaster in most cases). While the repairs will be minor, there will be a LOT of them to smooth out those tears before repainting.
Is there any way to prevent this, or is this just something you gotta live with? I should note that those shelf cleats were not applied to fresh paint; in fact, the paint on the walls to which I screwed the cleats was about four years dry.
A.J.
