Finishing hard maple & bloodwood.
Dan Mitchell
>Here are some pics of a table I just completed out of hard maple & bloodwood. I'm wondering what type of finish to apply. I have read that alcohol based finishes (like shellac) will bring the bloodwood's red pigment into solution, muddying the wood's appearance & possibly running onto the piece's other areas. I've seen tung oil suggested for bloodwood, this would probably bring out the grain of both species nicely and be relatively easy to apply (finishing is definitely NOT my strong suit), but I'm not sure tung oil will seal/protect the wood very well. Another concern I have is that the inlayed bloodwood trim around the top may be problematic with seasonal expansion/contraction of the maple substrate, and that I should seal the top well on all 6 surfaces (top., bottom, edges)while its stable. Any thoughts appreciated!
TIA
Dan
Re: Finishing hard maple & bloodwood.
Image 2
Dan Mitchell
Image 3
Dan Mitchell
I'd consider a 3-part system
>Part 1 is a tung-oil finish to pop the grain and seal the bloodwood. Waterlox sealer comes to mind with apply-wipe off-reapply-wipe off routine.
Part 2 is a sealer coat of Ultra Blond dewaxed shellac. SealCoat will do if less than 6 months old. 2 coats of 1 lb cut are called for here.
Step 3 is to topcoat. To keep the piece as light as possible, I'd go with an acrylic or CAB lacquer to keep the topcoat water white and light, but still build "depth" in the finish with good clarity.
A lot of thoughts here...
>First, I can't see if the bloodwood edging is long grain or short grain, but if the top is solid maple, I would recommend using short-grain for the inlay.
Regarding bleeding of colors, the best thing to do is always to try a test sample. Glue a scrap of bloodwood to a scrap of maple and put a finish on it. Experiment. It might bleed, but maybe not.
Re: I'd consider a 3-part system
Dan Mitchell
>Thanks for the suggestions, Mark. A few questions:
1) Is Waterlox a brand/type of tung oil?
2) I gather "Ultra Blond" is a type of dewaxed shellac, rather than a brand. By SealCoat, do you mean this: http://www.zinsser.com/product_detail.asp?ProductId=72 ?
3) Is there a specific topcoat product you'd recommend?
I'm really new to finishing & need all the hand-holding I can get! ;-)
Thanks
Dan
>If you can spray, shoot it with a solvent lacquer; it won't bleed. If you have to brush, use a water borne poly; that won't bleed either. It's too late to worry about differential movement.
Clint
Re: A lot of thoughts here...
Dan Mitchell
>Ellis - Long grain or short grain, are you sure we're not talking about rice here? ;-)
Does this close-up help?
I will do a test glue-up as you suggest.
Thanks
>Too late for me to worry about Grain alignment too. I made a top and ignored grain direction. It warped into a trough. I threw it away and made another one. the first one is still thrown away.
If that grain is crossed, I'd fix it before going any further.
I'd spray it with lacquer, even if I had to use spray cans, but I'm not an expert on finishing either.
Dan Mitchell
>The wood used for the top was recovered from another table, without going into detail, the condition of the edge was such that I had to cover the outer ~1.5" for cosmetic reasons.
If the top is stable at the moment, why would sealing it entirely not prevent any change in both wood's water content/dimensions, and therefore also prevent the size from varying?
3 Parts *LINK*
>1.Waterlox is, indeed, a brand. Reason for tung is that it discolors less that linseed over time. You can use it on the entire piece or apply it just to the bloodwood to seal in the color.
2. Ultra blond or Ultra Pale is a specially processed shellac which is near to being water white, but is produced without bleaching the resin that can effect durability. SealCoat is the product you've linked to. While I mix my own shellac, I do buy SealCoat in small cans. It is rated for a 2-year shelf life, but I won't use it as a sealer after 6 moths from the mix date stamped on the can. All shellacs will, over time, react with their alcohol solvent in a process called esterification where the resin becomes soft and gummy, even after the solvent has evaporated. Therefore I mix small batches and buy small cans of ready mixed to minimize waste when I pitch the stuff.
3.I've used a number of waterborne products. The Target USL is an excellent finish that will, like solvent lacquer, "burn in" to the previous layer. Lately I've been using General Finishes Enduro poly with very nice results. For table tops, I add in the special crosslinker. Stuff flows out like butter and rubs out like polishing glass.
You can get lots of info and really expert advise on Jeff Jewitt's site, including his finishing forums. I also buy most of my furniture finishes from Jeff.
Jewitt site
Dan Donaldson
>The problem is that there is no such thing as "completely sealed". You may get away with it, depending on the environment it is used in and the specific moisture content at the time it was made. The issue is on the ends of the top where the grain runs in opposite directions, especially since the bloodwood is only on one side. If the top expands across the grain, the bloodwood will not because its grain is the other direction, causing the top to cup. The finish will slow down the moisture exchange, but will not stop it.
That's what I was concerned about
>The fact that the inlays across the width of the table are long-grain means that if the maple contracts, the inlay will want to blow out the side inlays. Short grain inlay at the end-grain ends of the top will not pose that threat in a significant way.
Fred Davis
>Dan ,
apart from the obvious grain direction problems , you can read the TDS ( technical data sheet) from Zinsser's concerning the use and specs of their Shellac.
Helps to get it from the manufacturer.
http://zinnser.com/PDF/TDB/BE_SHLLAC.pdf
FredD
