So, what should I do with my old furnace blower?
Joe Pack
>I will have a new furnace and heat pump installed soon. I am going to keep the furnace blower because I just think I should. I don't have a definite idea for it, but have thought of....super suction downdraft sanding table; second air cleaner at the other end of my shop; super-duty fan for my garage; ventilation for a finishing booth in the garage..
Any other practical ideas? Red Green ideas also considered. :-)
Also, any reason to keep any of the old furnace myself? Is the coil worth anything as scrap? I'm not familiar with heat pump innards...anything worth keeping there? The installer will haul the old system away, n/c.
Re: So, what should I do with my old furnace blower?
Recycle the old furnace keep the blower
Forrest Addy
>Recycle the old furnace. Keep the blower for the uses you projected. A beefy blower is a great house ventillator in the event of painting fume, minor cooking disasters. It also has the shop use you mentioned. If you don't feel a clear and present need for a blower powered widgit, stash it and inspiration is sure to strike.
You can always toss it later
Dan Mitchell
>But once it's gone, it's gone.
I'd hang on to the blower, doubt the rest would prove useful.
I have several.....
>One I have had for a very long time that is serving as an air cleaner in the shop. Had another I had saved and started making a downdraft table. Decided it might be good to test the blower first and let the smoke out, tossed it. Now I have three more a friend in the HVAC business gave me. Perhaps another air cleaner and a down draft table. Be aware that many of them are 240 volt motors. Might want to look at and label the wiring before stripping it. I am at something of a loss as to how to reconnect mine.
It might be worthwhile to save what ever tracks its mounted on to reuse as mounting hardware, but I doubt it.
make a fine dust remover
Bill Tindall, E.TN
>Put it in a box or use ceiling joists for the "box". and put a fine house filter on one side of the box with upholster batting for prefilter. Suck through this side and exhaust through another side of box. This arrangement works great for circulating shop air for taking out fine suspended dust.
Howard Norman
>By keeping the old blower I am assuming that you will keep the motor for it also. You should keep both as far as I am concerned. Never know when you will have a need for them.
Will keep both
Joe Pack
>Yes, I will keep the motor and the blower/frame. I will find a use for it; getting around to actually doing it may be another. :-)
Re: Will keep both
Bill Turpin in WNC mountains
>Be sure you keep the run capacitor for the motor. It is usually mounted on or near the motor, but sometimes is in a control box. Get the wiring diagrasm also.
Good points
Dan Mitchell
