Jet Dust collector Question
Andy Lincoln,in Dearborn,MI
>Hi All,
If anyone has a Jet DC-1100 with the 6" inlet could you measure the diameter of that impeller cover plate?The piece with about 12 screws holding it on?I bought a Steel City DC used and they only offer it with a 4" wye fitting.I found a part supplier on-line who has the impeller cover for around $20+s&h for the Jet.Before I begin to hard pipe my DC I'd like to go with 6" ducting and only reduce where I have to,I would hate to start by expanding 4" into 6" if I could avoid it.
Thanks,
Andy
Re: Jet Dust collector Question
Thomas S Stockton------WebKitFormBoundaryRU4sWQOIA
>If it doesn't fit you can always take a jig saw to it and then make an inlet out some extra 6" pipe and pop rivet it on. Worked for me.
Tom
Joe in a Cleveland suburb
>Andy,
I have the DC-1100. I'm not sure though what you need measured. If I take the black plastic 'Y' adapter off and expose the impeller, the opening is 6".
Need anything else? Want me to take a picture of what I'm talking about?
Joe
Does this help?
>This
and this
sorry for the not-so-great image quality. I was using one hand...
Re: Does this help?
Andy Lincoln,in Dearborn MI
>Joe,
what I am looking for is the diameter of the piece you removed to show the impeller in picture # 2.
Thanks,
Andy
14 inches
Thanks,that was what I needed to know.
Update on my DC
>Hi All,
I went back into the shop today to do a preliminary layout of my intended ductwork/hard plumbing.While looking over the DC I failed to notice that the 4" wye on the Steel City leads to a 6" inlet on that housing.I think it will be a simple matter to cut the 4" wye off the face side of the DC and begin my plumbing with 6" material.I am now waiting on a friend of mine who is an air handling specialist to get back to me about my faxed over layout sketch and his supply of 6 in spiral duct and fittings.He has the specs of the DC and what I think the duct layout should be and hopefully I will have the optimum set-up for the equipment I have.
Andy
