Above Floor Flat Surfaces Collect Stuff
charlie belden
>I've developed a motto for my shop "In order to do ANYTHING, I first have to move EVERYTHING". Seems any flat surface above floor level attracts "stuff" to be piled on it - typically in several layers (ok - many, many, many precariously balanced layers). Clearing off a flat above floor level surface is like a combination of an archeological dig - and a stroll down memory lane. And it's not unusual for me to find things I don't ever remember buying or acquiring, some I have no idea of what it's for or does.
Now part of MY problem is that I'm a Wood Horder, though a sawyer friend refers to me as a Wood Whore - who'll do almost anything to acquire MORE WOOD. SO - I save those "this could be used for SOMETHING" cut offs and scraps. I also seem to have a collection of old door knobs and hardware, a couple of 5 gallon buckets of drawer glides I picked up for a song at an auction, bits and pieces of In Progress Projects. Then there are the woodworking books and magazines. Take one out - and it never makes it back to its shelf.
But I think I've come up with a partial solution. ALL above floor flat surfaces that can be tilted will be tilted a few degrees beyond at some as yet unidentified Angle of Repose (the angle at which something will slide off onto the floor).
Now I realize that this may pose a danger to bench planes and bench chisels, as well as other hand tools. But all of them do already have a home in a wall hanging tool cabinet.
That leaves layout and assembly needs. Now if I put a slide up when in use, slide down when not, lip on my now slanted surfaces, the layout thing will be half solved. Magnets may take care of the rest. Hmmmm - a steel topped layout and assembly bench . . .
So what clever solutions have YOU come up with to solve the Piles and Layers Problem?
Re: Above Floor Flat Surfaces Collect Stuff
Recycled
>All the kitchen cabinets when we put in the new kitchen last winter. Now most everything's in drawers or behind doors. Way easier to keep thing clean.
Four drawer file cabinets
Tom Dunlap
>My shop and storage are a lot like what you described :)
A cheap solution is to get four drawer file cabinets. Solid and roomy. The tops do make for another collection depot though.
I try to follow the mantra of 'Don't put it down put it away'...with partial success :)
Re: Big cabinet, shallow drawers
Brian in Brighton
>I made a cabinet with many shallow drawers. Things can only pile to a shallow depth before the drawer can't close. I made mine 2 inches tall.
Brian in Brighton
Now, where did my table saw go?
Solve?
>I have the same problem.
A friend of mine, who was majoring in engineering before switching to social work, said all furniture consists of boxes and flat surfaces - the boxes to put things IN and the flat surfaces to put things ON.
I'd Be Inclined To Use The Angle of Repose
>Good Afternoon Charlie,
But it would be a slippery slope for sure!
George
So!!! It's YOU, Wrecked my shop didja?
>I wondered who "organised" my shop. We must have learned in the same class. For me, what's worse is that if I ever clean up a spot, my son buries it. I once cleaned up the room next to my shop with the idea it would become an assembly room. I left and came back several hours later and I had inherited a dog tread mill. Stunning.
Your description was amazing. Identical to my experience. I thought about doubling the size of my (small) shop. My friend who has a much larger shop said, "check this", and opening the over head door on the back of his shop, revealing the addition that increased the shop by about a third. It was full of junk. Then he showed me the building behind that that doubled the size of the shop and addition and it was full of stuff also. His answer to doubling my shop was "Don't do it, it will just fill up."
As cluttered as my shop is, there is some underlying organization. For instance, when I do clean up and put things away, my son can find it all and drag it back out. I have shelves and drawers and cabinets. The discipline comes in establishing places for things and then putting them away. (What a laugh). The closest I have come to a solution is what I call the "ten things rule". I would never manage to actually clean up, but I CAN do ten things. So when I get ready to leave, I put ten things away. When I return to the shop I put ten things away. Sometimes, twelve things. I know it's simplistic and stupid, but it helps.
What's THIS?!
>Layin' down on the job? No no no
Biggest problem with slopes is you gotta always be watching' for what's comin' down atcha.
PS
>But I STILL can't keep track of pencils!
Re: PS
Howard Norman
>>But I STILL can't keep track of pencils!<
I buy them by the dozen and put a dozen here, a dozen there. At least it helps for a few months.
steve mackay
>Racks & More Racks. Over head/over bench/within arms reach racks, under the bench racks and over head racks in the garage. Mostly its the discipline to cut what I need from the stock and IMEDIATLY return the stock to a rack. I don't set it on the bench while I finnish roughing out the workpiece. I shut down whatever machine I'm on and get the stock put up NOW. Of course I'm also the guy that forgets which is the stock and which is the workpiece. Then I've got to get the ruler out and figure out which is which. Gandalf the Gray would have said : "Mackay's mind is like a lumber room . . . thing wanted always lost."
Garden Gnomes
Curly Smith
>I once thought that I had a clutter problem. I'd clean the shop, put everything in its proper place, and then the next morning the shop would once again be in disarray. I knew that I wasn't the problem, it had to be somebody else so I installed surveillance cameras, cleaned the shop and discovered, much to my horror, that my shop was infested with Gremlins.
Fortunately, much of what we call "folklore" is actually true and a solution to my problem was readily available. I was able to entice a family of Garden Gnomes, which are well known to be mortal enemies of Gremlins, to live outside of the shop. After a fierce and epic battle the Gremlins departed for safer environs (perhaps your shop?) and my shop is now free of clutter. I should caution you, though, to be careful in selecting your Gnome family. If you mistakenly attract Shop Gnomes then you'll never be able to use your tools again as they will constantly be making all manner of devices that you're better off not knowing about and there is no known method for eradicating Shop Gnomes.
charlie belden
>Though I've got storage racks for ply - 4' long with slots for full sheets, half sheets, quarter sheets and some for miscellaneous sizes, I still have pieces of MDF, 1/4" oak ply, half inch baltic birch and so on leaning against things - which is the OTHER problem I have. And it's not like I don't have shelves for boards - 16' feet long, five high that start 4' off the ground so machines can be stored up against the walls when not in use (thank god for the invention of the wheel). AND I've got wood racks behind the shop as well.
It's those damn odd widths and thicknesses, in Too Long To Throw Away, Too Short To Fit On Shelf Brackets. I've tried stacking them carefully to optimize the shelf space - but then I NEED one on the bottom or middle of a pile. Then it's like playing JINGO. Can I take THIS one out - without the whole stack falling apart?
The filing cabinet idea seems a good one - at first glance. But if you've ever had to dig deep - in a deep drawer, this "solution" creates more problems than it solves. SHALLOW is better - no digging.
When we USED to have garbage pickup that'd take cut offs I didn't have this problem. Now we've got a Yard Waste Can (and god help you if they find anything other than grass clippings, prunings and leaves in that can), a Recycling Can (which also doesn't allow wood unless it's obviously fresh off a tree or bush) and the smallest of all the Evertyhing Else Can., which, once the week's garbage is in it just might hold the equivalent of an 8' 2x4.
And since I live in California, you can't burn the damn stuff - no Burn Days here. What I NEED is one of the V-8 driven giant chippers - and a truck to shoot the debris that comes out of it into.
Hmmmm - kids - and forts. I've managed to be persuaded by neighborhood skateboarders to part with some 2x4 scraps and some beat up ply. Maybe I can convince them that my other "shorts" are treasures they can put to good use.
I sure am glad I'm not a segmented turner. THOSE folks never throw away ANY piece of wood.
Now where the hell did I leave that nail set - and the chuck key for the drill press? ARRRRGGGHHHH.
Moreso
>Certain of the family strains carry a raging case of OCD and will not tolerate anything out of place for even a minute. You can always identify a shop so infested by the tools being outlined in white on pegboard walls varnished to a high sheen, and the presence of small signs about the place such as "Put It Away Before You Leave", "Square Pegs Don't Fit In Round Holes" and "Cleanliness Is Next To Nothing".
Transgression of the rules can transform them into Shop Trolls, but you really don't want to go there.
Don't Disturb: I KNOW Where Everything Is!!!
Kneale Brownson..Awaiting return to CO snows
Marv
>My shop is totally, unbelievably cluttered, not to mention, messy.
However, it's all by design. My work surfaces are covered with tools, but they are the tools I use most often, so why be putting them in drawers and hanging them on pegboard when I'll just have to go find them in the drawers and take them off the pegs, probably the next day.
But the real mess is on both sides of my table saw and all around my bandsaw with just enough room for my feet to shuffle around in the sawdust and scraps. Lots of times though, I can find just the piece of wood I need for that special little project by digging around in the piles. I hate cutting a small piece of wood from a big piece. That's just plain wastful.
I have narrow pathes winding around my shop from machine to machine and workbench to workbench. The other day I dropped a bolt and of course it bounce under the bottom shelf of my bench, that's where everything goes when I drop it. I can be on the other side of my shop and drop something. Instead of looking around on the floor close to me, I might as well just go over to the bench because it will be under the bench. While digging around for the bolt I found stuff that dated back at least 15 years. Nothing useful mind you, just scraps of metal ends of bolts I cut off when shortening the bolt that I recognize from a project that is still a crisp memory of long ago. I can't remember what I said three seconds ago, but I can remember that cut off bolt and all the details of the project that needed a shorter bolt 15 years ago.
I pretty much know where everything is, but I must say, I do spend some of my limited hours left to live looking for things from time to time. I always find it though, because I know for sure where ever it is, I was the one who put it there. No one else ever enters the openings to my shop unless I lead them in and point to a bare spot on the floor where they must stand and remain until I lead them back out. I threatened to handcuff one guy who kept touching things.
I never throw anything away. At one time it was good, no reason why it isn't still good.
Marv
Jim Pugh, Elyria, OH
>Charlie, get some quarter size heavy duty magnets and put one on the side of your drill press someplace handy. Always return the chuck key to the magnet. It will not fall off or wander away without some help.
Jesper, Denmark
Re: A simple rule......
Jesper, Denmark
>In my shop there is a very simple rule of order:
You may leave stuff where you are working with it, but you may not move to any other location, except back in it's proper place.
If something is in the way, put it back where it belongs, not to some other place.
As you can imagine, it does not get followed 100%, but close enuf............
Carlos Clarke
>I'm getting rid of as many flat surfaces as I can. The big router table has been replaced by small, portable tables that can be stacked. The sanding table is going away. All of the nuts, bolts, and screws are going into drawers.
I have three containers for saw dust, small scrap that isn't burnable, and small scrap that is burnable. If I need a small piece I can look through the scrap containers. If the containers get full they get thrown out. Large scrap gets stacked with the rest of my wood.
I only have one pencil. It forces me to keep track of it. I used to keep one by each station and could never find any of them. I keep my other layout tools close to the pencil.
I have a spot on the wall near the door where I put screw drivers and other old tools. Those are the ones my wife and kids can borrow. I don't mind losing those. The good tools are at the opposite end of the shop.
Of course it has taken 30 years to get to this point and I'm still fighting clutter so I don't think it will ever get solved.
