Nice Gun +
>Watch your gun pressure or you'll defeat the HVLP quality; 25-30psi is about max. Using a gun-mounted mini regulator will give you much more precise control.
Your shellac: If you mix from flakes, make a fresh batch for your piece and before you use it, run it through a paper coffee filter. If you're using SealCoat, make sure it's not more than 6 month's old from the "born-on" date on the can. Here's why: From contact with Jeff Weiss, the owner of Target Coatings, I learned (the hard way) that they, and other waterborne manufacturers, have been having problems with cold checking (coating fractures) of a shellac layer under their waterborne coatings. Much of the problem may be esterification in the shellac because of age that is further compounded by too heavy a shellac application.
The remedy is first to use only the freshest dewaxed shellac for your sealing coat under the waterborne. If you (as do I) use darker shades of shellac to tone and blend parts of the workpiece, consider using some Transtint dye in the shellac and using less shellac. Two light shellac coats should be enough to give you some grain "pop" and prevent the waterborne from raising the grain. BTW, DO NOT use a "wetting agent" in your shellac as you'll get fisheyes a/o adhesion problems in waterborne topcoats.
Next, be sure to let your shellac dry very well before applying the waterborne. I wait at least 24 hours, longer in humid conditions. You need to let the alcohol fully migrate and evaporate out of the shellac layer or it messes with the topcoat chemistry.
Topcoat: Since you're using a minigun with a lower application rate, consider using some Target SA-5 retarder in your Target finish, and keep your gun moving close to the surface (6-9 inches). It gives the coating a bit more time to flow out and level, and gives better penetration of spray mist into corners and details. In my view, it's pretty much required when spraying with RH levels below 50% as waterbornes dry so quickly that orange peel gets to be a real issue. The SA-5 will help, but you'll have to be more careful about runs and sags on vertical surfaces.
Hope this helps. Remember to practice on some scrap.
mm
