Anyone use Freud Dial-A-Width Dado Set?
Dan Mitchell
>I have a Freud 8" "Pro" dado set which I use fairly often, and even with a set of plastic Veritas shims, oftentimes I find getting the exact width I need to be a real PITA. I'm wondering if the dial-a-width is easier enough to use to justify the price. Anybody use one? Or know of another option?
TIA
Dan
Re: Anyone use Freud Dial-A-Width Dado Set?
Jim Shaver - Oakville, Ont, Canada
>Hi Dan,
I have had mine for 10 years and I love it.
I have made precise width measurements to set up the click settings to get exact fits with all sized work. I would recommend it if you want a process with no shims, makes using metric plywoods a breeze.
Take care,
Jim.
Howard Acheson
>The Dial A Width is an excellent dado. It produces clean cuts and is easy to adjust.
However, if you have Contractor or Hybrid saw, you may not be able to use the dado for its full width. The adjustable hub takes up room on the arbor screw preventing the addition of all the chippers.
The hub takes up 7/32" of arbor so the calculation for maximum dado width is: Total Arbor Length - 7/32" - Nut Thickness = Maximum Dado Width (up to the manufacturer's stated maximum width). Arbor length is 1 1/8" plus the thickness of the nut.
Dan Mitchell
>Thanks for the replies. I wasn't aware of the arbor length issue. I have a PM2000. The arbor is 1 3/8, the nut 5/8. The Freud site states the following on this issue:
"Arbor Length�Measure the length of the arbor on your machine and subtract the thickness of the arbor nut from that measurement. If what you have left is at least 1-3/32" then you can cut up to a 3/4" dado with your saw. If you have 1-3/16" or more then you can stack all the components on the arbor at one time."
The figure for the PM2000 using the above would be 3/4", so obviously I could not use the entire stack, at least not with the stock nut. I'm not sure what this translates into for actual cut width, but using Howard's formula, I get a paltry 17/32 for maximum dado width. I could probably substitute a somewhat thinner nut to gain a bit of space, but if 1 3/16 length is required sans-nut to accommodate all the chippers, I'd need to use a 3/16" thick nut, obviously not a good idea, even if I could find one. A nut of 9/32 thickness would be required with this arbor length for a 3/4" dado.
If this modern, full size cabinet saw will not accommodate the entire stack, I have to wonder what saw will. I'll bet a lot of buyers have been disappointed shelling out nearly 300 bucks for this thing, only to find out they can't use it effectively. You'd think if nothing else, they could sell smaller (CHEAPER) sets with fewer chippers for what has to be the vast majority of saws which are not capable of utilizing the entire stack.
Thanks for the heads up.
Dan
