OT: Home Networking Questions
Rob Hix - King George, VA
>I really hate to post on OT, but I cannot find another forum for this question, and I know some here work in networking.
I am about to wire my house for a network. I want to shoot for gigabit ethernet. Ok, now for the question. Can I use a telephone punch-down block to terminate the ethernet runs or should I use a switch?
Once again, sorry for the OT. Thanks in advance for the help.
Rob Hix
Re: OT: Home Networking Questions
waroland
>Use a Switch. Telephone punch blocks are exactly that, telephone voice quality. You don't want lousy connections after putting in Gigibit network cables.
Dave Paine
>If you want Gigabit ethernet you should check that you have Category 6 cable. "normal" ethernet cable will be Category 5 or Category 5E. Category 6 has better shielding which is desired for the higher bandwidth.
I am not sure what you mean by terminating in a switch.
If you are connecting two computers, and only two computers, you may get by without a router or hub, by using a "cross over cable" which has wires in a special order, two of which are crossed.
Most networks use a router or hub. If you are connecting only between devices in the home, you can get by with a hub. Check that the hub supports Gigabit speed.
If you are connecting between the devices and to the outside internet, you will need a router, which will provide IP addresses for the devices within the house.
If you are connecting all devices with cables, then it should be fairly straight forward. The router manual should provide the details. A hub should be power-up and plug in ethernet cables.
John McGaw
>I'm not really sure what you mean by using a telephone punchdown in this context. I would say that you should use nothing that is not rated for the speed you are trying to achieve and telephone blocks are not up to the task. Even a too-loose or too-tight twisted pair can impair correct operation. Typically house wiring will be done using solid twisted-pair 8-conductor cable. It is best to use at least CAT5E if you are hoping to achieve "gigabit" throughput. CAT6 is even better but is expensive and more touchy about installation. I put the gigabit in quotes because you will never achieve that speed -- most people would be happy to get half way there and most don't achieve even that.
At the computer end of each run there is typically a wall-mounted female RG-45 jack. Each of these has it's own termination arrangement which is similar to a punchdown and which requires no stripping. The connection between the wall jack and the computer equipment is typically done with a ready-made CAT5e RJ-45 cable of suitable length.
At the other end one needs a way to transition between the solid CAT5E to the switch (or hub). There are male RJ-45 connectors made for use with solid wire but in my experience these seem unreliable, especially if the cables are moved frequently. After bad experiences with them I avoid this method. I usually recommend a patch panel although one could simply install more female RJ-45 jacks to make the transition. From either the patch panel and the switch, short flexible ready-made patch cables. I really prefer the patch panel route but either one will work. In my own home installation I used a patch panel which I already had on-hand and which now carries all of my network and telephone cables. Each room has at least one dual wall plate with both an RJ-45 network and a RJ-11 phone connector.
Was that sufficiently confusing? ;-)
Bill Howatt
>I ran some cat5e cable in my basement before I covered the walls. I terminated the cable in standard electrical boxes. You then have to get the female portion of the RJ45 which mounts in the faceplate or is the faceplate depending on the vendor. These will often have a punch-down connection method. Then use standard male-male cables to go from the wall socket to your computer or router or whatever.
While this stuff used to be only available at specialty stores you can find it building centers these days. I ususally snoop around the local Home Depot to see what's available now. I also recommend stranded cable only. Follow the directions carefully and you will have no problems and don't drive staples tightly onto the cable to hold it in place; you don't want any pinches.
Bill
Ken Garlock, Collin County Texas
>Hi Rob.
When we built in 2002, I had nearly 1500 ft. of Belden 7878A home automation cable installed by our electrician. Each room has 2 outlets, each consisting of 2 RG6 coax, 2 Cat5 E ethernet, and one Fiber. All runs terminate in a steel wiring cabinet in a closet. The antenna lead-in from the satellite dish also terminates in the wiring cabinet. Each wire in the cabinet is itself terminated in a connector, be it coax or RG45. From there it is a simple case of using jumpers to make the connections as required. The ma bell service is patched from the panel into one of the ethernet runs, allowing us to have two phones in each room if for some weird reason the need should arise.
Rob, do some googling of "home automation cable", and remember good cable is spelled B E L D E N.
Foot note: ethernet cabling up through 5-E is known as USTP cable: Un Shielded Twisted Pair. I can't speak to the 6 series....
Happy wiring,
Ken
Warren Johnson
>1. Use Cat 5e unshielded or Cat 6 unshielded cable solid copper for all the runs from wall plates to server or router.
2. Shielded requires special tool to install RJ-45 plugs if used and cost for RJ-45 jacks will be higher.
3. Cat 5e will be about 1/2 the cost of Cat 6.
4. Install a 12 port patch panel incloset and as someone else mentioned, use premade stranded wire patch cable to connec from panel to router/switch.
Joel M. Dibbern-Kramer
>Rob what I think you are thinking of is similar to an office environment where there is is a run of cable between a computer/terminal equipment and the network equipment that is located in one central place. There are three wire components and two hardware components to this run. At each end there are what are called whips, these are lengths of cable that have a RJ-45 male connectors at each end of the cable. These cables go from the wall/wall connector to the (equipment side) computer/terminal/printer, and the on the other side which goes from the network equipment to the wall/patch panel. In the middle there is a run of wire that runs between the wall connector (equipment side) to a patch panel (on the network side). This layout ensures that that if the cable ends of the Whips or the cable/whip itself are damaged that go between the equipment and the wall you are only required to replace the Whip and not the full run of cable. Both the wall connector (equip. side) and the patch panel (network side) have to be certified for the service that you require. If it not than do not use it, it will only cause you trouble in the end. In answer to your question (Can I use a telephone punch-down block to terminate the Ethernet runs or should I use a switch?) The short answer is no, and the reason is that voice communications only require a CAT-3 level wiring/equipment, and you require 5e or better wiring/equipment. Also note that there is stranded as well as solid wire which would require you to buy the correct/appropriate connection hardware. You would have to make sure that the hardware can be used with the wire that you are planning to use. Generally they are not interchangeable. There are are pros and cons to using one type of wire over the other. The solid wire has better electrical properties while the stranded wire/cable is more flexible than solid cable. FYI you are also limited to 100 meters for any single cable run. Hope this is not long?
Excellent answers, but I have a question
Ed Beck
>I used to run a corporate network and have some experience with cabling issues. For moving this amount of data around the shielded CAT5E or CAT6 home runs with switch boxes is the way to go.
But I have to ask, in a home network, why do you want gigabit throughput? I mean that�s a serious amount of data capacity. I can think of a couple of reasons, either moving lots of huge files around frequently, or streaming HD video. Other than that, if I was building a house or doing a huge remodel in which wallboard was removed I�d probably run the best networking I could get and say something like �but honey, as long as the walls are off we might as well run the best network infrastructure we can� (as I�m removing a good chunk of the studs to run conduit).
If you�re thinking of future-proofing, then you should probably take Ken�s lead and run a few different types of cable, including fiber, which is taking longer than I expected to get into neighborhoods.
Finally, if you�re moving lots of data around your home network fine, but if your primary purpose is to pull data down from the internet then your bottleneck is going to be where it comes into the house. I don�t think that any internet provider is offering anywhere near the throughput that would make use of a gigabit infrastructure. You�d turn the faucet on and the 1�s and 0�s would drip out of the RJ45.
Hey, I�m all in favor of overkill, I don�t own a single computer that doesn�t have its RAM maxed out, and my woodshop tools are all more powerful than I really need (�but honey, if I get the 3 1/4 hp router it�ll be able to handle anything I ever might want to do and I�ll never overstress it�). But there comes a limit to what I can afford.
I guess all I�m saying is that it�s going to cost a lot more to get a gigabit capable infrastructure than if you aim lower. With the savings you could follow Ken�s lead and run multiple data transport media.
Hey � Important tips!
  • Leave plenty of slack in the cables.
  • If you run conduit then plan for expansion and use more conduit than you need now.
  • Be sure to leave a pull cord that will never, ever degrade to each outlet. You may never need it but if you do you�ll feel so smart. A feeling which can rapidly go away if you didn't remember to include a replacement pull cord with the cable you just pulled.
  • And don�t forget the tone-back equipment, it may not be as entertaining to any observer, but figuring out what goes where will be a lot easier.
>Thanks all for the answers. A couple of hours after I wrote the question I found my answer. It appears that a 110 punch block can be used for networking. However, you will share your bandwidth among all of the computers. With a switch, every computer has full bandwidth back to the switch. Two computers talking to each other in the house should get the advantage of full bandwidth. At least as I read it.
The reason I want gigabit capability is indeed for HD video. I have a DVR set up on one of my computers. Currently I have no high def sources, but it never hurts to plan ahead a little.
Once again, thanks.
Rob Hix
Re: Excellent answers, but I have a question
Bill Howatt
>Fair question and as always, it goes back to what you want to do even if you don't need to do it. A 10 Mbps connection is adequate for a cable or DSL connection.
The gigabit connection is a bit misleading because the real-life data transfer rate achieved is not a gigabit/second - probably less than half that.
I keep my files on a central computer to make backup easier and to allow easier access from all machines and it is nice to run at about HD speeds across the network. For large files it is noticeable compared to a 100Mbps link.
I don't think there is much of a price penalty these days to go with gigabit switches and NIC cards - in fact a lot of the better motherboards come with gigabit connections.
Bill
Bill
Warren Johnson
>A 110 patch panel has nothing to do with the saring of band width. It is for the organization of the cables which run from various rooms to the equipment closet(routher/switch).
If you have a 4 port routher/switch, and use a short patch cable from that to the port on the patch panel, the patch panel is an invisable connection so to speak. Just be sure to maintain "like" components, cable,wall jacks, patch panel, and patch cables. All Cat 5e or Cat 6, for best results.
Ed Beck
>That makes sense.
One comment, next time that you need / want to replace your data storage computers, take a look at network storage. I'm using a 1 TB Western Digital network drive that I connect to my network via Ethernet. I'm mirroring the drives, so my capacity is down to 500 GB. By the way, I don't recommend this drive, the access time is too slow. Next time I replace them I'll look at some of the LynkSys network drives.
