We value your privacy.
>Just finished applying the last coat of lacquer to this piece of redwood. Still needs to be wooled and waxed. It'll be the top of a coffee table with three legs of textured and colored 5" steel pipe. I hope to have it welded up by next weekend.
This is very nice looking. I have had a redwood burl for over 30 years and never quite knew what I wanted to do with it. How many coats did you put on it? I would like to see the finished product for further inspiration.
>Merle, it has about the equivalent of 4-5 full wet coats to even out the sheen among the flat and end grain areas. I suspect it was cut from a stump or root in a burned over location, as some of the edge looks charred. I used a water white alkyd lacquer from Sherwin Williams to enhance the figure without turning the whole thing muddy, which a penetrating oil would have done.
>Total spray job. After the first wet coat dried overnight, I rubbed down the nibs with 220 drywall screen and brushed the edges with a soft brass brush. Subsequent coats were done in one day, letting each coat harden enough to shave off any pimples with a sharp chisel before spraying the next. The final step was to spray a full wet coat of almost straight reducer to level and even everythin out. In a couple days I'll rub it down with 0000 steel wool lubed with Butcher's wax and buff with old toweling.
I have found that Acetone will remove felt pen ink immediately, if not sooner. *grin*. Just trying to be helpful here....
Regarding spray on Lacquer, seems that the dimpling is common. I was thinking it was just me. I use it on reconditioned saw handles and have tried everything I can think of to get a glass smooth coat without having to steelwool it, but with no success. I usually give it about four coats. That represents a lot of steelwooling.
