Who has a bench top mortiser?
Richard Jones
>And how do you like it? Brand? Pros? Cons? Does it tilt? Hold down features?
Thanks.
Rich
Re: Who has a bench top mortiser?
Dan Mitchell
>A few weeks ago, I got a General Int. 75-050T. I've only used it once, but it performed well on some very hard maple I'm making a table out of. The mortiser does tilt, which was one reason I picked this model, though I haven't used that feature yet. On the down side, it is one of the more expensive 5/8" bench top mortisers.
In a review of mortisers, FWW named the 75-050T "Best overall", and the Woodtek 138-224 (which looks identical to the non-tilting General 75-050 M1) as "Best value". For those whose "wallet is really squeezed" (their term), they suggested the Delta 14-651.
Dan
>I have a 15 year old Delta. It's accurate enough and worth the price.
Clint
>Good Afternoon richard,
I bought the Shop Fox #W1671 a couple years ago. It was superior to other bench top motrisers commonly available in 2003. I coupled it with a cross slide vise obtained from Harbor Freight for around $50. The Shop Fox features a 3/4 hp 8 amp motor and can use both 5/8 or 3/4" shank chisels. It can swing over the edge of the bench to take on longer stock vertically. The mortiser is used with a gas spring to assist in raising the head of the machine. There are three positions for the gas spring, allowing for maximum board thicknesses of 4 1/2, 6 1/2, and 8 1/2 inches. I also bought the set of Fox Shop chisels from Grizzly, and they work well. Conical sharpening stones from Lee Valley are worth their weight in keeping the chisels sharp. I use my mortiser with a great deal of pleasure. The cost was only slightly above the 1/2 hp models from Jet and Delta, which I test drove before deciding. The machine has operated flawlessly. The gas strut did fail, and was inexpensively replaced by Grizzly a couple months ago. Its a very nice tool, but get a cross slide vise.
George
I'll drink to that
Ken Garlock, Collin County Texas
>I too have the General International 75-050T. It is a real beast weighing in at nearly 100 pounds, not what I would call a bench top. I built my own stand, with casters, so that I can sit down on a chair while using it.
I have used it to cut all the mortises in my workbench, table for LOML, and the stand for my Nova DVR-XP lathe. I havn't used any other mortiser for comparison, but the 'beast' did a good job. Regardless what you buy, get a set of chisels from Lee Valley along with their honing tools.
Oh yes, expect to pay in the neighborhood of $500 plus for the beast.
Good Luck with your shopping,
Ken
Re: I mounted my Delta
Kneale Brownson..Awaiting return to CO snows
>on a stand so that I could turn the head around on its post and install a four-way vise to move the stock more accurately. After learning how to hone the bits and mount them properly, I've found the tool to be serviceable.
I've got the basic one that several co.'s re-label
John in NM
>Mine is a Jet, but is the same as several others. It was under $200 when I bought it, and worth the price, but not as pleasant to use as some of the bigger models. So if budget is less of a consideration, get some options like cross slide, vise, and a more robust mast and return mechanism. The best import I've ever used is an old Bridgewood model that uses a cast iron weight for return instead of a spring. If I could afford or even find an old Wysong and Miles, that would be the first choice, but the Bridgewood would be second (and much more likely!).
mdclor
>Rich, I have a Jet bench top morticer and it works okay. The hold down is also okay. I had the opportunity to use a PM floor stand model and it was really head and shoulders above the Jet unit. If you will be doing a lot of mortices and have the floor space, I suggest you at least give this class of machine a look.
HTH,
Merle
Still Like My JET  *LINK*
Review
Re: Still Like My JET
Dave Bair, Eaton Rapids, MI
>Me, too. Less than $200 new and it's still punching square holes in white oak. I've worn one of the chisels down far enough to warrant a replacement this fall. The machine will probably last longer than me.
Thanks guys..........
Richard Jones
Tony - Memphis
>I have the Powermatic (701 I think). It works very well. The hold down is ok. The wheels that keep the work against the fence work good.
Tony
Re: Who has a bench top mortiser? *LINK*
charlie belden
>Have the General International 75-075M, used only for larger through mortises - bought when I was making my Real Workbench. Since acquiring the Festool DOMINO it hasn't been used.
But if you're in the market for a chisel and bit mortiser here are some things you want to have
1. An XY table. Fixed tables mean having to either put spacers between the fence and the part you're mortising OR move the fence and hope it stays parallal to the back side of the chisel - which it probably won't. Trying to register agains a 5/8" or 3/4" chisel side is not the best idea.
2. You want a really good Hold In/Hold Down. Once you've got the part aligned with the chisel you DO NOT want it to move while cutting.
3. You want it to be able to handle different diameter shanks on the chisels - so you want a collet for the larger diameter.
4. You want a handle that is long enough to give you some leverage - and who's position can be adjusted/changed. Having to stand on a stool to reach the handle at the start of a mortise operation ain't good.
5. You want dovetail ways that can be shimmed for adjustments - and a rack and pinion gearing systems to move it up and down.
And what ever you get, hone and polish the sides of the chisel - and get one of those Cone Sharpeners - for the inside edges of the chisel. Lee Valley carries a set of two for not a ton of bucks. Dull chisels make mortising a LOT harder.
And check out the Forty Cent Method for setting the proper chisel to bit spacing. Getting THAT right can make mortising so much easier and quicker.
Forty Cent Method for Setting Chisel & Bit
