Wood + hot iron
Wood + hot iron
Wood + hot iron
Randy Johnson Connersville IN
>What would be a good wood to use for handles (turned)where the main purpose is to insulate the heat from hot metal?
I've been asked to make some replacement handles for the tools used for welding plastic gas pipe. Making them will be easy enough but I want to use something that won't char TOO easily. My guess is the harder and denser (hedge, hard maple, beech)the better.
My job doesn't require using these tools so I'm not sure how hot the part where metal meets wood gets. The current failure seems to be more along the lines of cracking than burning
Apparently the company that makes the tools doesn't sell replacement handles. The company I work for has three different districts, so if the first few I make work well in my district I might be making quite a few of them.
Re: Wood + hot iron
Possible idea for you
>I'm guessing these are like chisel handles, but from your description, I really have no idea. In any event, one approach might be to provide a certain amount of space between the wood and the hot metal and fill it with furnace cement or other insulating material. Otherwise, any wood is going to char and/or crack from the conducted heat. Dense woods may actually crack more but hold up better to charring.
Re: Wood + hot iron
Re: Possible idea for you
>The handles are more like sleeves - more or less akin to what you would see on an electric soldering iron.
On the two tools I looked at, one had the handle secued with a pin and the other by nuts and washers at the cord end.
I hadn't thought of using furnace cement. It could solve another problem I've wondered about as well. Being able to bore the proper sized hole through the handle. With furnace cement I could go over a little. I'm going to have to talk a little more to the guys who are using these things and make sure I understand how they are being used. The other day they said I would be able to increase the diameter very much.
Re: Wood + hot iron
Re: Another Possible idea for you
Kneale Brownson..Awaiting return to CO snows
>Can you get one of the OEM wooden handles to "disect" and see how it's made? I've made a number of replacement handles for pans and covers used on a stove by just replicating the size and configuration of the originals. They've never gotten too hot. Used mostly walnut.
Re: Wood + hot iron
Ken Oakley-Sunny St. Cloud, Fla.
>How about Corian? It is used for counter tops so must have some heat resistance. From what I read it is a good turning material. Shops that manufacture counter tops of Corian should have scraps available.
Re: Wood + hot iron
Re: Wood + hot iron
Alexander Grigoriev
>I've read paulownia is quite fire-retardant.
Re: Wood + hot iron
Corian is heat sensitive
Phil Joines Krum,Tx
>It's a plastic and can be heat bent. I haven't done it but I understand it acts a lot like plexiglass.
For hear resistant handles I'd want a wood that didn't have a lot of oils. Maple or cherry would probably char at a lower temp than something like oak.
Re: Wood + hot iron
what ever turns best
Bill Tindall, E.TN
>I don't think it matters what the wood is. All wood is cellulose and lignin. Because all wood is chemically identical it is going to respond to heat the same, that is its decomposition temperature will be the same. Beech would be a good choice because it is cheap and easy to turn.
Re: Wood + hot iron
Why not Phenolic? *LINK*
Eddie Pacheco: Antioch, Ca.
>McMaster-Carr sells this in tubing form and all you would most likely have to to is radius the cut ends and possibly some shallow grooves to make it look custom.
McMaster calls it Garolite.
Phenolic/Garolite tubing
Re: Wood + hot iron
Re: Why not Phenolic?
>Some people call it Bakelite. It stinks terribly when machined.
