Shop Vac as a Demo tool.....
>I am working on a house for my cousin. Part of it is 150 years old and the addition is 100. It was built on a dry stacked rubble stone foundation. One front corner appears to have settled about three inches. We tore out the floor to get to the sill laid on the stone. It started life as an 8 x 8 oak beam. It had rotted so badly that it had compressed at least two inches. We temporarily supported the ceiling of the room and cut out the beam. The inside came off and was about a 1/2 inch thick. Then we just sucked up the rest of it with the shop vac. I think this is the first time I have used the shop vac as a demo tool.
We replaced it with treated wood. The beam we took out had been there 100 years. Wonder if the new one will last as long? The wall under the front double windows had rotted so badly that the vinyl siding is all that is holding it together. That was the third layer of siding. (Weather boards, Cement Asbestos, Vinyl.)
Re: Shop Vac as a Demo tool.....
Justin Szeliga
>I was doing work in Guam installing radon systems in Naval housing & we had to excavate a pit under the slab after boring through the foundation wall. Most of the guys would go at it with a screwdriver to loosen the soil, rock, or whatever was under there, then pull or vacuum it out. I thought for a moment, figured American contractors in the 50's & 60's, pouring concrete in the tropics, there's gonna be a helluva lota beer bottles under these slabs. I wasn't going to stick my hand in there. Then I remembered what I guy told me about getting loose stone out of some block cores that needed to be filled with concrete. He used a shopvac & presto, empty cinderblock. I duct taped a flat prybar to the end of a Sears shopvac wand & used that to loosen the fill & the vac would suck it right away. I now use my shopvac to clear dirt out of any holes I need to dig. Much easier & safer than using my hands, & makes a cleaner, smaller hole than a posthole digger.
