200+ woodworking book reviews
Festool routers OK?
Festool routers OK?
Jesper, Denmark
Festool routers OK?
Jesper, Denmark
>I have a repair job in Germany in a week or so, where I needed a couple of routers for a weird routing operation on some vertical surfaces.
Sionce my shop here is wired for 115 Volt and allthe existing routers are Porter Cable 115 Volt, I needed some that run on 20 Volt and can be repaired or use bits and accessories available in Germany.
Specifically they are a OFK-500 trim router and an OF 1400 plunge router. Other than the bits for the trim router have a weird non-standard method of attachment with a screw down the bit, they seem very handy and well made.
It will be e bit of a triock modifying the trim router bit, as I cannot have the bearing mounted on the bit as I need to use it.
Any comments with these tools from the collective wisdom of the board?
Re: Festool routers OK?
Henry Higginbotham
>I have a 1400 and love it. I really can't speak to durability under heavy use, but as far as handling and smoothness of the plunge and controls, nothing else I've ever owned or used comes close. Sounds really nice, too (for a router, anyway).
