Delta 50-760 improvements
Chuck in ND
>As some of you may have figured out, I bought one of these units and there were a couple things on it I felt could use some improvement. First thing I didn't care for how the frame would rack from side to side, I like things a little more stable, so I added some cross bracing to the back, much like scaffolding has. For this task I didn't want to drill into what I feel is a pretty light duty frame and weaken it more, so I used 1" metal clamps w/cushion to attach the bracing to the frame. It really sturdied things up and I highly recommend doing it.
Re: Delta 50-760 improvements
Chuck in ND
>The second improvement isn't as criticle as the bracing, but I plan on adding a second stage, so I decided I wanted a full shelf on the botton, something that wouldn't scratch when sliding the dust bin in and out and wouldn't vibrate. For the shelf I went with a 3/8" Masonite board with a rubber mat glued ontop.
Chuck in ND
>And last, here is the steel drum that I plan on useing for the second stage setup, I just need to think a little more about how I'm going to attach an inlet to the drum or lid.
Re: Delta 50-760 improvements - Thumbs up.
Ray Carson - Lawrenceville, NJ
>Maybe you should send these pictures to Delta. Looks like improvements that should already be included in THEIR design.
Ray
Kneale Brownson..Awaiting return to CO snows
>I have a very similar DC sold by Shopsmith years ago. No longer in production. You will need your chip barrel to be sealed, otherwise the stuff in it will blow all over. I use a regular opaque 35-gallon heavy duty plastic bag much like the ones Delta apparently supplies. You can see the chip buildup and can change out the bag (I save most chips for garden use)before it fills to the top, which makes the change kind of messy too.
>I have a different Delta DC. I have changed all around. I mounted it on a piece of plywood, eliminating the base and rollers that came with it. I installed it in a exterior I built outside my shop for the DC. I have a metal trash can that sits below it and I use clear poly bags in it. There is four or five inches of free space between the DC and trashcan. In theory you should be able to see the dust in the free space, but in fact the bags get so dusty its hard to tell. I have to go out there and touch it to be sure. A "bag is Full" sensor/alarm. The bag in the can makes it easy to attach and to empty.
Starter switches
Phil Joines Krum,Tx
>Don't know about your model but all the Deltas at work (about 12, 1 and 1-1/2HP's) all have the start switch under the end bell cover where it's exposed to the dust. They want about $60 for a replacement. It's a good idea to blow the dust out when you empty the bag.
Chuck in ND
>Ray, I agree, the improvements should be included, and so should a 110/220v switch. Currently the unit comes with a 110v switch, the 110/220v switch is available through Delta, but at a questionable price.
Re: Double check the switch!
Brian in Brighton
>Mine was rated at 240VAC when I got it 2 years ago. Same model. You need to read the little printing on the side of the switch. I don't remember if I pulled mine out or not to see it.
I don't think it's legal by NEC for them to sell a motor that has a 110-220 conversion diagram in the peckerhead without the switch actually being able to handle it.
Brian in Brighton
Chuck in ND
>Hi Brian, I checked the old switch this morning, it says 125/250vac. The thing is, it only has two connections on the back, the new switch I got from Delta has four connections.
Chuck in ND
>Ray, I sent the idea in to Delta. We will see where it goes from there.
