So I have this Plastic laminate countertop
Glenn Madsen near San Francisco
>Replacing a warped, water and steam damaged IKEA counter top installed a couple three years ago this week. It's cut to length, and I'm dropping the sink into the cutout I'm making now.
It's Home Depot plam, and the substrate is particle board.
What can I do to the cut edges to increase the water resistance?
I have ALEX Plus caulk, and GE Silicone 1 caulk on hand. There's 15 kinds of finish materials in the shop at home, 2 miles away.
This job is too much work for the fun involved. How can I make it stop?
Re: So I have this Plastic laminate countertop
>You can always trowel on some roofing cement. %>)
Clint
>Well, I have some red stuff that I used when I redid the master bath shower a couple three years ago. Recommended from the John Bridge tile forum, got it at the Borg. Maybe that would be a good idea. I'd forgotten that.
Not going to do an asphalt type emulsion, though.
Thanks for the idea generator. Sometimes mine hiccups.
Fred Davis
Fred Davis
>Glenn,
a job like this should make you carry some PolySeamSeal in White and Clear.
If your sink is on top of the counter, spread some Poly on the cut edges of the PB and then run a heavy bead around the cutout and mash the sink into it and clean up with a wet cloth.
No leaks ever.
FredD
Bill White
>Laminate tops require a drop-in sink. Caulk the sawn edge and the top area covered by the sink lip, press in, use the sink retaining clips. You're done.
Bill
