Please help, what kind of screw is this??
Thad
>I've got a repair job that requires me to remove trim that is fastened with these screws. I cannot seem to find a name for them anywhere, and also cannot find a driver to remove them, but I would like to.
It's not Torx, as there are some of those also...as well as Security Torx. These have 8 points, not 6, but are in a star-like pattern, not a true octagon.
Please help.
Re: Please help, what kind of screw is this??
Dave Peebles Lyons, Ohio!
>Hi Thad,
I do not know the name of it, but it looks like a square drive may fit it. If you have those it may be worth a shot.
Good luck,
Dave
Dick Coers
>Maybe called a double square? Try using a square drive and see what happens.
double square bit
GolfSteve in Calgary
>Volkswagen loves those. Try to find a bit at an autoparts store. When I used the name "double square bit" the person behind the counter knew what I was talking about and found the right bits although they were called something different.
Torx
Lee Schierer - McKean, PA
>I believe they are called torx screws and are widely used in the automotive industry.
Lee
Re: Torx
Robert R. Clough - Thorncraft
>Yes, it is a Torx. Locally Elliotts Ace carries them and seems to be replacing the square drive with them. Rocklers also has them. I expect I'll need to get a Torx drive set.
It looks like the Torx pattern...
>... at first glance, but Torx screws have a six-lobed socket and these have an eight-point pattern. I've never seen this pattern before. I'd be interested to know if a standard Robertson bit would drive this screw, i.e., is the size of the square recess compatible with one of the standard Robertson sizes...?
Re: Please help, what kind of screw is this?? *LINK*
wilbur
>I found a website that refers to this as an "8-point exterior trailer screw".
In any case, they sell a driver for it, for the princely sum of $0.99.
8 point screw drive bit
P.S. *LINK*
wilbur
>According to an eBay listing I found just after my post, a square drive bit will also work with these.
8 point screws on eBay
THAT'S IT!!! - Thanks a ton.
Thad
The square drive works
Thad
Re: double square bit
Kneale Brownson..Awaiting return to CO snows
>I've never seen "double square" fasteners on a VW or Audi (I've had a bunch of both), but commonly they use "triple square" fasteners that have 12 points.
>On my VW's, most fasteners are either phillips or torx (6 point bit).
For some reason unknown to me the bolts that hold the doors hinges in place, the door strikes, and some suspension stuff use the 8 point double square bits. I think it has something to do with the amount of torque that can be applied with a torx bit vs. a double square bit. The double-square bit really grips.
It's frustrating to get half way through a repair job and realize a bolt requires a double square bit when you thought it needed a torx bit.
John McGaw
>If I'm not misinterpreting the geometry in the link's photo, what they are offering is a standard square drive bit. That would explain the price -- it is dead common.
