Return to ? for Physics Gurus....
Alan Young
Alan Young
>Here's the project I was messing with last week when I asked about the sagging and bending of a rod vs that of a square shaft.
The answers were great fun to read-even though I didn't understand most of them :^) and in the end for my use the difference between a dowel and a square piece of wood was moot.
While fitting the shelves for a set of bookcases-( See earlier posted thread-Painted Book Shelves) I was irritated by the bending of my ruler and the movement of the hook tab on the other end. So I came up with this little gauge. This is nothing new but I found it helpful to set the space for cutting the shelves.
I set the full rounded dowel end toward each side of the case or space in question.
A small tightening of the set screws keeps the dowels set at the inside spacing.
I can then take measurement of the dowels end to end.
By reversing the full ends for the tapered ends you can also check for square between corner to corner diagonals. This gauge can uses 3/4" dowels. Cutting the dowels to different sizes allows for different sized openings.
I made a smaller set out of 3/8 bolts. This be used for measuring small distances.
Alan
Re: Return to ? for Physics Gurus....
Why not.......
>do what I do? Buy your bookshelves with shelves pre cut in the factory. No, wait...Could you cut the shelves first and then build the cabinet to fit them???
Why not just use two small sticks of similar size. Lap them the way you have in your little holder, but without the holder. Put a tick mark across the sticks. Then you can move them to the board you wish to cut, reset them to the tick mark and mark the board. This is a very old way of marking trim. You can spiff it up a bit by putting a standard tic on one stick and a piece of tape on the other. After the taped is all marked up and hard to track, replace it.
GalenV in Iowa
>Alan
OK so I forgot to ask what material! I was thinking steel so using
Modulus of Elasticity for same to get deflections.
Being a "man of steel", no relation to Superman, I retired from structural steel work to work in wood. Still use steel for measuring.
I use a round 3/8" white curtain rod for getting inside dimensions. Slide it out to fit inside and marked the rod. Many times you had to push it back together to get it out of a spot but then slide back out to mark to measure.
Galen
Folding rule with a slide *LINK*
>up to six feet plus of shelf length.
They appear regularly at garage sales.
like this one, for instance.
I like them
Gary Camp, Bend, oregon
>The other solutions mentioned will all work just fine, but they are just not as elegant.
glc
Re: I like them *LINK*
Jim Toews - Walla Walla, WA
>Lee Valley/Veritas makes something similar. I made a set of four that allow me to measure anything from 5 inches up to 5 feet. Very handy, and I don't introduce inaccuracies through mismeasurements. Great product.
Cheers!
Jim
Bar Gauge Heads
Alan Young
Re: I like them
Alan Young
>Hi Jim,
That's pretty much what I was thinking of when I made my set. I remember my grampa using a set like that many years ago-He made his own.
Alan
Easier and Simpler Solution - Slip Sticks *LINK*
charlie belden
>You are after a distance between to fixed objects - and you don't care about the units of measurement. What you're after is something that's "this long" - no tape to read or misread (is that 3/32nds or 5/32nds?). Set the slip sticks to fit the width and clip them in place. Take them to the miter saw, set one end against a near side tooth, set a stop against the other end. remove them and cut your parts - to fit.
But if you like making tools and jigs . . .
Slip sticks - no "reading/misreading"
