Outdoor Epoxy?? *LINK*
Andy Lincoln,in Dearborn,MI
>Hi All,
thursday I go pick up an order of White Oak to begin building some outdoor patio furniture.I have a quart of West System epoxy resin105 and was planning to use either 206 slow hardener or 209 extra slow hardener to increase/utilize the long open times.The majority of the construction will be mortise and tenon as well as some laminations of the arms to get the bow-like shape.Should I add a filler such as 403 and/or 406?
Thanks,
Andy
http://westsystem.com/ss/
Re: Outdoor Epoxy?? *LINK*
Re: Outdoor Epoxy??
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>It has been a long time since I used that brand, but yes, it would be a good idea to thicken it when you use it for adhesive. Because of the slow set time, it will drain out of the joint if it can.
Although I have never had problems gluing oak with epoxy, the literature says that it can be a problem. Probably because oak is dense, and epoxy doesn't penetrate the cell walls. It needs a mechanical grip on the surface to hold onto. So don't use a lot of clamp pressure. You can squeeze too much out of a joint to have enough left to work, due to the slow set.
Unless you are working in an extremely hot space, and mix a huge volume, I would not be too worried about open time. If you want more time, just mix small batches, like a cup or two, then spread them onto the wood quickly. Once it is thin coat, you have plenty of time to work.
When you have too much depth in your container, is when you get a fast kick because of the heat build-up.
Unlike most other glues, epoxy will still have good strength is it squirms even after starting to jell. So don't panic.
Also,
Re: Outdoor Epoxy??
DizD
>I used this epoxy to build my shop doors a year or so ago. A friend who is a dealer/user of this recommended that the joints be done in two stages. Use unthickened mixture first - this thin mixture will soak into the wood. Follow with a mixture thickened with wood flour. As he explained if you put the thickened mixture on the wood first, there is not enough liquid to soak into the wood to get a good bond. I used an old cake pan to mix in to keep the temperature down and maintain the open time.
