Bar Top Finish
Bar Top Finish
Bar Top Finish
Mac in Indy
>I am making a desk and coffee table for my son's college apartment. We decided to try to match the look of the tables at Noodles & Co. They look like plywood on edge. We took some 2x12 LVL lumber ripped it into 1 3/4" strips, rotate 'em 90 degrees and re-glue them. A lot of work but not too difficult. I will run them through a local lumber yard's widebelt sander to smooth them.
Here is the subject question: I was thinking of using a product that is used on Bar and restaurant table tops. I know nothing about it and wanted some feedback from those that have used it. How is it applied? what about the edges of the table? Any info is appreciated.
Thanks!!
Mac
Re: Bar Top Finish
Re: Bar Top Finish *LINK*
Dave Pashley
>I'm at the same stage you are trying to figure out what to use. The Mirrorcoat video is helpful. but using an open flame around it doesn't give me a warm feeling. product is available at Rockler. Good luck I'll be interested in any other suggestions as well.
Dave
http://www.systemthree.com/p_mirror_coat.asp
Re: Bar Top Finish
Check www.systemthree.com
Re: Bar Top Finish
Pour-On Epoxy Finish
Howard Acheson
>The finish you are referring to is called a Pour-On two part epoxy finish. Google "pour-on epoxy" and you will find info that should help. There are a number of brands and probably little difference between them.
The problem you can have with this type of finish is that it forms an impervious surface and no air will pass through. However air will get to the underside and cause it to expand/contract with changes in relative humidity. This will cause the surface to warp or crack. Pour-on finish is best applied to a composition substrate like plywood or MDF which is not affected by changes in humidity.
That said, it is probably the most rugged finish you can apply but it rapidly gets scratched and cloudy.
While I am not a fan of polyurethane varnish, college dorm furniture is probably a good use of it.
Re: Bar Top Finish
Re: Bar Top Finish
Kneale Brownson..Awaiting return to CO snows
>You have to create a dam around the perimeter of the surface you're using this stuff on. Not too bad if you just want to do the top, but if you want to include the edges, it can get quite complicated.
I'm with Howard in thinking that if you're using solid wood, you should use a varnish.
