construction of an ellipsograph
McKay
>I have searched the article section, but I am unable to find anything on constructing an ellipsograph. (ie. mechanical device for scribing an ellipse. ) Any one out there have a lead? Thanks in advance.
McKay
Re: construction of an ellipsograph
Ken Oakley-Sunny St. Cloud, Fla.
>I made mine from a book by Patrick Spielman titled "Router Jigs & Techniques". ISBN 0-8069-6694-7
Re: construction of an ellipsograph *LINK*
Dick Coers
>Don't know if you are going to use a knife, pencil, or router with the jig, but here is a link to Rocklers with a video. Not much to make your own out of MDF or hard maple.
router ellipse trammel
GalenV in Iowa
>You did not say if you want the jig to just draw an ellipse or maybe router or saw an ellipse.
Rockler has one you can buy for a router but you can see it would be easy to make one of your own.
Rockler ellipse demo
Skunked by one minute! :>)
GalenV in Iowa
McKay
>I actually want one that has the sliding dovetail that has a bar that slides in an 90 deg. "X". Thanks though.
Those in the links would have limited use
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>When you consider that the length of each track needs to be the length of the difference between the length of the long and short axis.
If you want to do a fairly fat ellipse, these would be OK, but if you want to do a long slender shape, the tracks need to be longer, and the ones to the short sides need to be able to be removed to get them out of the way.
The set that I made about 30 years ago are just a bunch of scrap plywood which I sawed a 1/2" dado down the middle and some across half way, then followed with a T-slot cutter. I then made a UHMW slider for each axis.
Also, I clamped pairs of parts in the vice with the grooves facing, and a key align the grooves, THis key had a T off the end, which I ran the edge of the router base against with a dovetail cutter.
I then put a fence on that router and ran some lengths of solid stock to make butterfly keys which could be cut off to insert into the aforementioned cuts in the ends of the parts . I can snap any number of parts together to make tracks long enough to room size ellipses or down pretty small.
If you are going to make a set, you should make it to work with a router. If you just mark it to cut to the line, you will save a lot of time trying to get a fair curve.
Two nails, string and a pencil
Al Kapocius
