OT Anybody got Mitsubishi Mr. Slim split Heat Pump
>I'm converting a house into four apartments. Each one about 700 SF. Was thinking these small ductless systems might be about right. Anybody got one or have experience? How noisy? How economical to install and operate? How long do they last?
Re: OT Anybody got Mitsubishi Mr. Slim split Heat Pump
Kind of...
doug f, san clemente, ca
>Barry - I've got the Fujitsu equivalent in a room about 16 X 20. It heats and cools quite nicely. Installation was interesting, but this was new construction so we could improvise as we went along. It's difficult to say what it costs to operate since we've only used it sporadically for about a year. On the low speed setting, it is very quiet.
Hope this helps a bit.
Doug
Re: Kind of...
Fred Davis
>Barry,
we had a Mitsubishi installed in the Sun room I built over a front patio slab and the Heat produced by that kept the main house AC running continuously in hot weather.
It's a Mr Slim Model MSH12/15 split-type heat pump, AC with electric coil heat backup for the heat pump , when the weather requires it.
The Plumber mounted it about ten feet above the floor on the inside parallel wall.
Requires a 240 V. line with disconnect for the heat exchanger and we dumped the condensate line in a handy adjacent Plumbing stack vent.
It has a wall mounted remote that has a steep learning curve , one the Plumber couldn't handle, but you will get the hang after about four readings.;-))
It's been in about eight years , only maintenance required is to keep the washable filter clean so you won't plug up the condensate line.
I like the unit very much and have in the past seen a a use for it in other climes and didn't know it was available.
It keeps a 480 S.F.
Sun room toasty inn the winter and as cool as you want in the Summer and it's been hitting upper nineties for about three weeks straight.
I don't know what they are going for now , but this unit installed was a little over two thousand dollars.
FredD
