OT Waterproofing a vase
Rich in MN
>The LOML has a ceramic vase that leaks. Any ideas on what I can use to seal the inside? It has been glazed and fired inside and out but still leaks.
Re: OT Waterproofing a vase
Ken Oakley-Sunny St. Cloud, Fla.
>New glaze can be applied and the vase refired.If it is an antique take it to professional.
John Veerkamp, Western Mo
>I have a favorite coffee mug that developed a leak. I coated the inside with thin CA glue. It has held for three years now. I use it with both hot and cold liquids. I just dumped a surplus amount into the mug and then swirled the mug around to coat the inside, I dumped out the excess and let it cure for several days before using. You have nothing to lose by trying.
John
Corn flakes
Al Goldstein
>Put some water in the vase. Then take a handfull of the breakfast cereal Corn Flakes and rub the flakes between you hands to break them up into very small pieces. Drop them in the vase and stir the water. Soon the leaks will stop.
I know this sounds crazy. I heard about it from a friend who had a very old house with old plumbing fixtures. The toilet had an overhead tank made of wood with a zinc lining. When the tank started to leak he didn't want to replace it, so he searched for and found the original plumber who installed it (yes, he was very old). The plumber asked for a box of Corn Flakes and fixed the leaks as described above. It's the gluten in the corn flakes that blocks the leaks.
Apparently, this was a common fix for leaky radiators on old cars. When radiators were improved and the fins made smaller this fix would not work (it would also block the fins).
We think we are so smart in modern times, but the old timers had a few neat tricks up their sleeves.
>Something on the order of the CA glue - how about a thinned epoxy? I've used it to "line" wooden vases and it has worked for them.
Re: Corn flakes
Tom Pilsbury (Chicago)
>If you don't have Corn Flakes you could try Frosted Flakes. They're Grrrrreat!
But don't use Rice Krispies. Too much Snap, Crackle and Pop.
(Aww. This is too easy. I'm gonna go cut some wood.)
Re: Corn flakes
Dick Coers
>Plus no gluten in the rice. I'm gluten intolerant and all my "bread" is made with rice flour. Rice bread won't stick together worth a hoot. Just barely tolerable to eat as well.
