OT: Weird ceiling fan problem
wilbur
>I just installed a pair of ceiling fans in our two boy's bedrooms today. They are your basic ceiling fans, with 3 fan speeds, lights that take CFL bulbs, and I got the remote controller so that they can be controlled from the wall switch. One got installed without a hitch. WIth the second, there's a weird problem.
The remote controller has buttons for fan speeds and a "fan off" button. There's another button that turns the light on and off. There's also a master switch that completely cuts power to the ceiling fan. The master switch needs to be on for the remote control to work, so although the fan and lights may be off, there is power to the ceiling fan (actually, to the remote control receiver) if the master switch is on.
Here's the weirdness: When the master switch is on, and the light button has the lights turned off, there is flickering with the lights. The flicker occurs about once every 1-2 seconds. Once I turn off the master switch, the flickering stops. The fan and remote controls work perfectly otherwise, and when the lights are on, they work fine.
Any idea what is going on? The only theory that I have is that when hooking up the ceiling fan to the electric wires, I might have reversed the neutral and hot connections, and somehow that's causing the flickering, but that's a bit of a stretch. I would imagine more things would go wrong if I did that.
