Removing saw burns from hard maple
Dan Mitchell
>I'm making a table out of hard maple with some bloodwood inlay trim. I noticed when I tapered the legs on the table saw that the maple burned fairly easily, and these burns took a surprising amount of sanding/material removal to eliminate. I encountered the same burns when cutting the edge of the top, which I also tapered on the table saw, a bit like a raised door panel. If anything, some of these burns are worse than the ones I experienced on the legs, especially on the end grain. An image is below. Is there any way to remove such marks, other than sanding away (or otherwise removing) the darkened area? Can it be lightened a bit (by some bleaching process, maybe?!?) to minimize the amount of wood which has to be removed?
TIA
Dan
Re: Removing saw burns from hard maple
This will be interesting.....
>I am thinking NO, there is no "trick" for removing the burns. Partially because its more than just the color. The polished burned area would look and finish differently even if some sort of bleach could remove the color. The bleach would also affect the surrounding area and they both might be white or lighter, but the burned area would still have a different texture.
I await the wisdom of the assembled masses. I will be impressed and pleased if there is a simpler way than scraping and sanding. When I have burned areas, I get artsy with the ROS and some nice fresh sharp sandpaper. All the way across the end.
I'm sure you don't want us to tell you "don't do that". Use a different blade or keep the work moving, or don't let the work bind against the blade and keep it going in a nice straight clean line.
If you had the right router bit or the right setup with a bit you have, you might be able to clean it up with that. I think the key here is to be consistent. Either saw it cleanly, route it cleanly or sand it into submission. Keeping the nice crisp details is the trick if you decide to sand. A card scraper might be the best bet.
How bout planing it off?
Marv
an ounce of prevention......
Bill Tindall, E.TN
>1. Use the jointer to taper legs, or band saw and jonter, or band saw and hand plane.
2. Either your technique or blade is causing the burn on the end grain. It is burning because the side of the teeth are rubbing the cut. The cause could be not enough side clearance on the teeth or you are not feeding straight. I suspect the latter.
Re: This will be interesting.....
Dan Mitchell
>Thanks for the reply. I agree, sanding risks losing the edge, that's my concern. I figured the bleach idea was a long shot. I do have a couple cabinet scrapers, but I have never used these, in fact the edges are not even prepared (never done THAT either ;-), and as with using a plane (another tool with which I am minimally skilled), I'd probably end up inflicting damage even more hideous than the burns.
Sad to say.
If anyone does have any suggestions on minimizing such burns in the future, I'm all ears. The saw blade used was a new Freud 80 toother which generally gives a nearly glass-like finish; I found with this maple, my Forrest WWII required took WAY more feeding force for the tilted raised-panel cuts. May be time to get that one sharpened...
Dan
Re: an ounce of prevention......
Dan Mitchell
>Probably right about the feed being off. I had made a 10" high fence to aid in the process, but it's the 1st time I've done this on the table saw, though practice pieces in softer woods did not burn nearly as much. This maple is actually recovered from some ~50 year old furniture which had belonged to my parents, and it is rock-hard. I also tried tapering the legs on the jointer, something I have done in the past with good result (and again, with softer woods) but when I went to do the 2nd cut on the 1st leg, the cut was so large, it tore a large piece off the end of the leg (maybe also related to the hardness of the wood), which I had to repair, so I opted for the TS approach instead.
Dan
Ken Oakley-Sunny St. Cloud, Fla.
>I have had pretty good results in the past using a new utility knife blade as a scraper to remove the burn marks. It is still work but goes faster than sanding
I typically plane, then sand
Scraper
>So, you made a tall fence, angled the TS blade, stood the piece on end, and ran it across the blade? IIRC you have a better TS than I do. I have a almost forty year old Delta/Rockwell Contractors Saw. I have done exactly what I described and got the very same results you did, In my case on heart pine. Using a 40 tooth WWII Forest blade.
I think its two things. If the work pauses or even slows down you get the burning. Or, if your table insert is even a few thousandths low when the work piece drops off the actual table onto the insert, that drop of even a tiny amount gives you a burn.
Handling fairly large pieces by yourself is difficult to get perfect. I find that setting up finger boards or other devices to help keep the work presses to the fence may really help.
Also, make friends with your scrapers. I am certainly no expert. I thought they were some sort of ancient technology we had outgrown. Wrong. They are low tech, but much more sophisticated and useful that they appear. I do one of two things. Clamp the scraper in my vice with about an inch showing. File the edge square. I have a fine file I just slid back and forth on the edge. Mostly along the edge, not so much across it. If you don't have a burnisher, use the shaft of a screwdriver. Tilt it to about 80 degrees and stroke the edge firmly. Tip it the other way the same amount and roll a curl the other way. I generally ant see the burr, but I can feel it. May take tow or three strokes each way. You can do both sides of the scraper, giving you four cutting edges. Be careful, this thing is sharper that it appears and will cut you. Hold the two ends in your hands and press the center forward. Slide the scraper forward, pressing it with the thumbs. If you get to really going with it, the scraper will get hot. HOT
I find this tool to be very useful. You can do lots of things with it like clean up snarly grain or those burn marks. You can reduce or eliminate a lot of sanding. When it stops cutting, file it again and turn the burr again. On the Hand Tool forum they will give you lots of details. I am not into the Zen of scrapers or At One with mine, I just use them and wonder if I have failed to learn as much as there is to know. You can get good use out of yours in much less time than it took me to type this. Try it.
jerryburns
>I use a sharp block plane and work to the center so I dont blow out the end and have to repair that too
Fred Davis
>Dan,
since your in a hurry and haven't got the card scraper technique down, go to a local glazier and get a couple of pieces of double strength widow glass in a size simliar to the card scraper.
No practice needed and it will peel the burn down much faster then sanding.
If you do this , and I have , you might want to wear glove. ;-))
FredD
In The Future....
David Yoho
>As you mentioned elsewhere in this thread, it may well be time to have your blade sharpened. Especially if it's been a while. However, I've cut 6/4 and 8/4 hard maple with my sharp Forrest blade before and got burn marks too. Tried different feed rates to no avail. It may be more about blade choice and/or the sugar content in woods like maple and cherry that are the real culprits. Either way, I have learned and use a work-around that saves the day.
Whenever I am ripping or tapering parts from hardwoods, I always cut the pieces a little over-sized. So if I'm cutting a piece that needs to be 2" wide, starting with the rip fence edge freshly run over the jointer, I cut the piece to 2- 1/16" wide. With the depth-of-cut on my jointer set to exactly 1/16", I joint the freshly cut edge. This gets rid of saw marks and any burn marks.
This is not so much a solution as a fix. I'll bet lots of us get burn marks at times. Personally, I don't have the time nor inclination to worry so much about why it's happening. I know my saw is set up as accurate as it can be and my blades are reasonably sharp. The fact is - I know it can and will happen at times and I allow for that by cutting slightly over and cleaning up with the jointer. Even though I do it more to remove any saw marks, it's still a normal routine of mine that works.
Re: In The Future....
>I agree with David. Many of us are looking for THE WAY to do something. Most things can be done many different ways. Whatever works for you with the tools and skills you have is the right way for you. If it takes a few minutes longer, who cares. It's not a race.
I don't know how I would joint the edge of your table top. At least, not with the jointer I have, but I would consider jointing the legs.
I have tapered legs on my jointer, but I find the TS to be more comfortable for me. I suspect the jointer would produce legs that are slightly variable. Not sure I would get four identical legs, but the TS will do that well. IF I needed to clean them up, I would not hesitate to run them over the jointer for a very light pass. I am confident that I could do that and maintain them in a nearly identical condition. After talking so much about keeping them I identical, I'm not sure it is essential to keep them perfectly identical. If you can't see that they vary by 1/100" when they are laying side by side, they are good enough. By the time you spread them to the corners of the piece, no one will notice. The limit of this is hard to tell. With a good eye you might pick up a 1/32".
As an aside, I often lay my tapered pieces on a flat surface side by side and sand all of them at once with a ROS. This helps keep them uniform and helps avoid rolling the edges. You have to keep them nicely lined up.
Glenn Madsen near San Francisco
>I had similar tear out problems on the jointer, but with softer silver maple, air dried and only 8 months from the tree. The tablesaw and hand plane were much better tools for that application.
The hand plane, well, multiples of them, are really tools that any craftsman is going to need to come to terms with. Three or four of them is a start, sharp and well tuned. There is a whole quiet side here that can make recommendations on what to start with, and how much raiding of the secret wood cash stash will be needed. ;-)
>The jointer works well, often, but not always, and not ever for the cross grain cuts.
A well tuned hand plane, however...
Cross Grain Cleanup
David Yoho
>I agree, about using a plane for the cross grain if it is to be seen in the end. I've always found my scraper plane or low angle block plane sufficient for this task.
Thanks for the replies
Dan Mitchell
>I managed to get a pretty good result starting with a block plane & finishing with the ROS. The burn is virtually undetectable, but with minimal loss of sharp edges, etc. I'm not that experienced with a plane yet, and even set to a very thin cut, I was pretty nervous when I made the 1st pass over this very hard end grain. Have to get more practice with these "cordless tools", plane & scraper ;-)
Thanks again for the input.
Dan
Leg tapering on the jointer *LINK*
Dan Mitchell
>BTW here's a video of the technique I've used to taper on the jointer. It has worked quit well with softer woods, but even with a pretty robust machine (8" PM) the large cuts required were a handful on this hard maple, and resulted in a nasty tearout at the foot of the one leg I attempted for this project. As has been suggested, the best approach may be to do the bulk of the shaping on the TS & finish up on the jointer.
http://fw_woodworking.permissiontv.com/index.html?showid=115402
You are welcome and thank you for.....
>telling us what you did and how it worked for you. It seems to me that often we post suggestions and never hear how it came out.
I've seen that video before and I actually did a couple of practice pieces on my own jointer. Mine has been set at about a 1/32" for so long that I could hear the gremlins saying "Are you kidding?" when I tried for 3/8". It worked, but my machine was not as polite about making that heavy cut. I have only done a couple, but I still have some doubt about the repeatability.
