Related tool comments (Long)
>Removing the planer/sander washboard and oxidation and final sanding represented lots of hours over more than a week, employing a 3x21 belt sander with 36, 50, and 80 grit paper; a Kunz scraper plane, a 5" ROS, hand scrapers, a 1/4 sheet sander, and hand block sanders.
The belt sander is great for leaving its own ripples and a heavy scratch pattern that the 80 grit doesn't do much against without clogging and dulling quickly.
My skill at sharpening and adjusting the Kunz leaves much to be desired, so while it was moderately useful, between the tendency to chatter and constantly fussing with it, I moved on to a hand scraper in a fancy clamping holder with an adjustable bow screw.
That was a waste of time, since it's much easier and quicker to simply use a scraper by hand, finessing the angle and bow to generate those fine little curls.
I bought a Bosch 1/4 sander to replace an ancient B&D that lost its jiggle and was a pain to mount paper on. The Bosch takes paper with a clamp arrangement that pulls the paper tight as it clamps up.
As for paper, I had bought some Norton 3X 100 grit to try out a while back. Either in the 1/4 sheet or on a hand block, it's the best paper I have ever used: agressive and long lasting. So I dropped by HD and picked up packages of 80, 150, and 220. They are all great.
The rest of the project is downhill from here.
Clint
