some answers....
Bill Tindall, E.TN
>"What is the advantage of this style of cutting over the old method. ".......... I don't know for sure. But, when you are cutting logs to sell it is imperative that you not pull splinters out of the center (heart) of the tree. To eliminate this possibility the logger will "saw the heart out" of the tree before it goes down, by some means or another. This technique saws the heart out with a boring cut. We used other means of cutting the heart out that would be harder to learn than this technique.
No, there is nothing wrong with an experienced person boring with the bar. In fact three parts of this competition involved precise boring. It is used in many logging situations. It is a potential kick back situation for a novice.
Is this more "accurate" in that you can aim the tree better? Again, I don't know. I have dazzled "spectators" by driving stakes with other methods. It is the hinge that controls the angle of fall and every technique leaves a hinge. With this technique it seems easier to precisely align the hinge.
If you were out in the woods and did not really care about the accuracy, would you use the old method? I don't think everyone uses this method, though they all did in this competition. You ALWAYS care about accuracy. You don't want to drop the tree on younger trees, where it will bust, whee it will lodge, on the skidder or where it is hard to get with the skidder.
Once the wedges are driven into the side notches why are they not in the way of other cuts? There is only one more cut and it is opposite from the notch and behind the wedges. The bar tip reaches in the and severs this remaining part without getting close to the wedges. You wouldn't always use wedges.
You did not mention the distance stake again. Was the point of that to show that the logger knew where the top of the tree was and how far it would reach when it hit the ground, thus he was confident where to park his truck? Yes.
The announcer told a story of a logger who did two tours in Iraq. When he came home his guard unit went to help clear storm damage. He was taking down a damaged tree and realized too late that it could reach the road where a car had turned onto. He ran to stop the car and the tree started over. It killed him in the road flagging the car. One of the steps in felling a tree is to estimate where its top will fall. I dropped one on the dozer driver one day. Fortunately the dozer had a cover but I still took a lot of flak for the mistake.
