OT: Any automatic icemaker gurus here?
Jason Roehl in Lafayette, IN
>Okay, my icemaker is not filling--it's just dumping the water through a drain tube into the drip pan at the bottom of the fridge, basically filling said drip pan and dumping water all over the floor within an hour or so. Pushing the bail up does turn off the icemaker and keep the drip pan from filling.
Anybody have any experience or ideas on where to start poking and prodding? I do have a couple service schematics for the fridge, so there are some tests outlined there I could start with, I just don't want to reinvent the wheel if it's a problem obvious to someone more experienced than I.
Jason
Re: OT: Any automatic icemaker gurus here?
Fred Davis
>The last fridge we bought is a Maytag and regarding the ice-maker , it has been worked on numerous times , replaced once and the Maytag serviceman is no longer the "loneliest guy in town"
I know that isn't any help , but maybe a guideline to the next one.
FredD
Joseph Mulherin, Sr
>Jason, once again O mention to go this website for ANY appliance repair solutions: www.repairclinic.com
Click in your particular appliance and follow thru to find the solution and or parts to buy.
Bill Turpin in WNC mountains
>Turn the water off to the fridge. Remove the icemaker, they are all plug and play. Inspect the ice tray and the inlet tube for splits. They all have a water level control, some are electronic, some are floats, some have timers, etc. Make sure the floats are free to move. Make sure the electronic probes are clean of hard water deposits or iron. Some have logic boards that can go bad, some are electro-mechanical. Do a google search, "How to fix my XXXXXX icemaker." Have your model and serial #'s handy. There are many factory original sources on E-bay. Makers run from $75 and up. Most of them require a -5�F freezer temp to start a cycle. Any average mechanic with a little electrical skill can troubleshoot one. Your google search should get you a trouble shooting guide. Warning! The gear boxes are full of springs and gears that FLY apart when opened. Pull any electrical connections apart and reconnect to clean off any corrosion. Once you do all this the freezer will be above -5�, you will have to WAIT before further analysis.
Bill, NC refrigeration contractor
Just replace it
>You ought to be able to get a replacement from the manufacturer. I'v done it several times with different makes. PIA, but do-able and cheaper than the repair man.
Clint
Tony - Memphis
>My ice maker comes out with two screws. I usually just remove it to work on it. I've had to work on it several times. I've never had that particular problem, but I've had several others. They are pretty simple, so you can probably figure it out. Mine freezes up a lot. I just take it out and run warm water over it to get rid the the built up ice and that fixes it. We're researching new fridges now. Ours is around 20 years old. It is making some really strange noises and sometimes everything on the top shelf freezes. Hoping to replace it on our terms and not the fridge's!
Good luck with your ice maker. Let us know what you figure out.
Tony
Ding! Ding! Ding!
>We have a winner!
Mine was 3 screws and the wiring harness, but the little funnel that accepts the water from the fill tube was frozen solid, causing it to overflow into the drain instead of flowing into the ice tray.
Thanks a bunch--I'm glad I posted and waited before I spent a bunch of money I didn't need to right now.
Jason
Thanks, all!
>Tony had the winning suggestion, but I'm thankful for all the responses here. I'm a die-hard DIY type of guy, but that doesn't mean I've encountered every situation related to home ownership, though they're quickly racking up. Trying the easiest solution first has always been my M.O., but I've also come to realize over the years that's not always the cheapest route if the first few easiest repair attempts cost money and don't work. This was one time where the easiest repair worked, and didn't cost me a thing, save for a few minutes of my time.
Ironically, about 15 years ago, I worked in a Whirlpool replacement parts packaging warehouse. The only thing we actually assembled there were ice makers. I even helped them out for a couple days once when they were behind schedule due to illnesses or worker shortage. Crimp a few wires together, install a few screws, snap a few parts together and then plug it into the test panel. Of course, I did see a guy get his finger in one of the pneumatic wire nut crimpers--popped it like a zit. He left a nice little trail of human hydraulic fluid between the assembly area and the restroom. For as quick as he was moving, those drips were really close together.
Jason
