Can TREX be used to make a shed door
Don J
>I want to build a replacement shed door that's weather-proof.
I want to use use a "Trex" (plastic wood) 2x4 outer frame and 1x4 "X" supports; and back it with sheet metal fastened by screws. I plan to route about 3/4" on the back side of the 2x4s down to the 1x4s---like a picture frame recess. The sheet metal will be inserted in this frame recess with screws.
WHAT IS THE BEST WAY TO JOIN THE TREX PIECES? Screws? Splines and glue? Other?
The pic below shows the basic idea
Re: Can TREX be used to make a shed door
Craig in Silverdale
>I'd use my Kreg Jig and put it together with pocket hole screws. I'm assuming that the light gray area is the sheet metal. Glue will not hold to trex, at least not to my knowledge. Good luck, and let us know how it turned out.
Don J
>Thanks Craig. I read somewhere PVC cement will work on TREX, but the pocket hole idea may work.
>The only Trex I have seen was in the size of deck boards. 5/4 X 6 with rounded edges. It offers very little in the way of stiffness. Rubbery and the question comes up as to whether it is strong enough for a floor if the joists are even 16" oc.
Are you thinking of Alex? Its the white high density PVC "lumber" and available in many shapes and sizes.
It can be cut with woodworking tools and drilled and screwed. It can also be glued with PVC glue. I recently timed out a house with it and use the glue to fabricate some of the parts. It worked well, but none of the parts I made up would be under much strain as the parts of the door would be.
This material is also very flexible. The doors would lack rigidity. Might help if you laminated wood on the other side to stiffen it up.
How About....
David Yoho
>Don, I have a door setup like your picture shows on my shed. The building is about 11 years old and I've painted it twice in that time. The cross-buck pieces on mine are standard construction grade two-by material and the "field" or panels are what appears to be T-111 material.
I've had to replace several of the two-by pieces through the years but the T-111 still shows no signs of weathering. So I wondering if your Trex cross-buck idea plus some T-111 panels wouldn't make a better combination. It seems unless you used stainless steel, you'd still have to paint the sheet metal as you would the T-111. Given that, the T-111 would increase the rigidity of those doors.
Mine have the cross-buck pieces applied over the panels, which would eliminate your concern of how to fasten the frame pieces together. However, you could also go with your idea of recessing them into the back of your Trex frame. Either way, you would have much beefier doors. If primed and painted properly with quality stuff, the siding material should hold up just fine.
I wouldn't do it
>Trex is thermoplastic, which means that heat in particular will cause it to lose strength and stiffness in every dimension. Your sheet metal or plywood backing would give the door rack resistance, so it wouldn't sag -- assuming your hinges were attached to the backing -- but the backing, or the backing framework, would have to provide enough rigidity to keep the backing from flexing in the thickness dimension. (Otherwise, think of cantilevering a piece of plywood off a pair of sawhorses. The plywood would sag and/or warp because it doesn't have the beam strength to resist such deformation. It needs to be secured to a flat, rigid structure.) So, your doors would always be at risk of bowing out, being twisted relative to each other, maybe not closing right, etc. Maybe you could overcome that with turnbuckles. I wouldn't want to risk it.
Getting back to my rigid framework suggestion, you could build an actual wooden 2x4 frame (or use hardwood), then attach your trex elements to it. It would make a rather thick door, but it would have a better chance of remaining flat over time.
I agree
Bill Howatt
>Trex has very little structureal strength. Granted, it won't break and doesn't warp due to shrinkage/drying but it is not intended as a structure member and what's worse it is very heavy so any joints have to be stronger than normal. I had some 5/4 20' Trex decking boards and I could put the middle on my shoulder and both ends were on the ground on a hot day - might have done it on a cold day too. Although it is flexible you won't break it on 16" centers which incidently is approved by the manufacturer and you can overhang it, IIRC, 3".
I would make the door like a deck. Use PT (if desired) wooden structural members and then do the decor with 1x6 or whatever Trex. Trex does have the advantage over some other plastic woods that it is solid so having ends exposed is not a problem and screws will hold it tightly.
Bill
Re: I agree
jerryburns
>I did a table top out of trex a few years ago and cut it up about a year later after it sagged so bad it pooled water in the center I wont use for a deck any more to spongee
