Repairing Old portable Circular Saw Questions.
>I have an old B&D Builder's Sawcat (Skill Saw). It has gotten to where the blade will spin on the shaft. That is, the washer held on by the bolt fails to secure the blade to the shaft and allows it to slip.
I think two things have caused this. Over time, the washer has flattened and is no longer slightly dome shaped. The central part of the washer comes into hard contact with the end of the shaft before the flange of the washer locks the blade. And/Or the blades are slightly thinner than they used to be, ending up with the same result.
I tried to buy a new washer, but the tag is long gone off the saw and apparently they made about a dozen versions of it. A local (Non B&D) repair shop would not hazard a guess as to which one I might need or even if they were all different or the same. I have not been able to get to the B&D repair shop during business hours.
A result of the blade slipping is that the shaft is worn and the blades no longer fit snugly on the shaft.
What do you think of the idea of grinding about a 1/32" or even a 1/16" off the end of the shaft to compensate for the flattening of the washer? Or would it be better to grind the recess in the washer a little deeper? Or should I just hunt down the repair shop and get the right washer?
Could I build up the diameter of the shaft with something like JB Weld?
The saw is like an old friend and I earned my living with it for years, but I really don't want to spend a lot trying to repair a lost cause. Not sure how much life is left in it even with repairs. It's probably thirty five years old.
What saw would you buy as a replacement? I am not looking for a $19 HF special. Another "real" saw that will get the job done when asked. OTOH, times are tough and I can't afford a new best friend.
