Is glue lam exterior rated?
Brian in Brighton
>I need to build a couple of bridges over our dry creek. Figure about 8 feet long and 4 and 6 feet wide. I would like to use glue lam for the beams under the decking. As much because I sometimes can find them 14" wide on CL for next to nothing as that they are super strong.
Does anyone know if they are exterior rated? One of the neighbors had a scrap piece in his culvert for 3-4 years and it looked OK, so I think they might be good to go.
Brian in Brighton
Re: Is glue lam exterior rated?
>My understanding is that most of them have been made for interior usage. Like plywood, they were rated for brief exposure to the weather, something like six weeks.
I heard recently that one of the companies has started making them suitable for exterior use. You might check around or Google them. Still don't know it they are rated for soil contact.
GalenV in Iowa
>Not sure how decrative the bridges are to be over utilitarian.
For 8 foot span you could drive a small vehical over it if you used railroad ties as they are cheap around here.
Not sure what your decking thickness or material you have in mind. Four pressure treated 2x8 on 16" centers would be more beam than you need for small vehicals like a cart.
If you have creasote timbers available I would pick over the green pressure treated. Again you can pick up used 2" bridge decking for the beams.
You did not say if you want an arch to the bridge but for 8 feet not sure if you need to clear water, if the dry creek ever has.
Just kicking ideas as the laminate beams I would not use outdoors.
Galen
Fred Davis
>Glu-lams have been exposed to the weather for years without any adverse effects because the glue used to laminate them is water proof and the wood used is like all exposed wood, it needs to be protected with a exterior finish like paint.
You see them all of the time without noticing , most generally the exposed tails of hip rafters , where the hip required large load bearing ability.
For a bridge, keep them free of earth contact for at least six inches and well coated with a copper salt , like "Copper Green" a brand of it.
You should be good to go with that, though it sounds like a over engineered project , bridges have a fifty percent safety factor designed in.
FredD
