OT: Washing machne pump leak
Bill Howatt
>I have a 15 yr-old washing machine that seems to have developed a slight leak. The only place I can see water where it shouldn't be is in a small hole about 3/16"dia on the side of the pump where you would suspect the bearings are. It is leaking very little. Why is it there and would it be wrong to seal it up for now? There seems to be some black "greasy" material nearby the hole too.
Thanks,
Bill
Re: OT: Washing machne pump leak
>Automotive water pumps sometimes have those holes, too - outside the water seal, so that, when they start to leak, they leak there. I don't know exactly why they exist, unless it's to save the bearing from getting hit with water when the seal goes.
Sounds like a replacement is due. The black stuff could be grease from a failed bearing, or smutchy rubber from a failed seal (I've never understood exactly why the rubber on some seals decomposes so badly in failure mode - on a washer, I guess it's all that soapy hot water).
One comment: many washers have an anti-siphon device in the fill hose. On Maytags (not that I'm saying yours is, that's just what I have experience with), it's a one-way valve made of rubber that, eventually, fails. On our Maytag, you can tell when that happens because it gets water on the back wall of the washer, but it can be subtle - diagnosing it this last time, a couple of weeks ago, involved a flashlight, because the anti-siphon is tucked up against the top, way at the back of the washer. (Again on Maytags) the part's not too expensive, and, if you find yourself disassembling the washer enough to reach it, or if the additional disassembly required is minimal, you might replace it as a preventive maintenance move. This assumes that your brand of washer has the anti-siphon and uses a similarly cheap (though funky) solution.
We are blessed in this county with an appliance parts house that carries parts at less than factory prices, and dispenses knowledgeable advice with their sales. You might look up "Appliance Parts" in your yellow pages, and see if you are similarly blessed in your town.
Final comment: if you don't already have a catch basin under your washing machine, this is a message from the universe to get one. They're not expensive if you get the plastic ones, and ours has more than paid for itself in two years by saving our new floor when the anti-siphon device failed (one save so far - every one after this is gravy). The biggest problem is getting the danged washing machine in the catch basin. I found that stacking 2x4s inside and outside the basin until they were the same height, then sliding the washing machine over the 2x4s, then removing the 2x4s on each side worked, although you will need to be sure your curse tank is full. If you have a younger back than I do or have a couple of teenagers in the house, you might be able to do it just with brute force, but it's an awkward job either way.
Joseph Mulherin, Sr
>Bill, go to www.repairclinic.com, click on your particular washer and up will come a diagnostic telling you exactly what the leak is and how to repair it.
just fixed one
Bill Tindall, E.TN
>An easy fix and the pump was $65. Why no do it right?
Thanks
Bill Howatt
>The pump needs replacing and like the other Bill said, "why not do it right?". Anything else just delays the inevitable.
Thanks for the help.
Bill
