finishing dovetail drawers
chad milton
>Can anyone tell me how to finish the sides and inside of a drawer that has half blind dovetails? Drawers are already assembled and using maple. Staining exterior with english oak water based stain and topcoating with polycrylic semi gloss finish. But don't know what to do on the sides of drawers and especially at the dovetail joint. Any suggestions? Thanks.
Re: finishing dovetail drawers
Tom Rex in TX
>I sand them with 220 grit, wipe them down and use Johnson paste furniture wax on the outside. I don't do anything to the inside.
>IMO a drawer aint finished till the inside is finished. If it's ply or dull wood, I base coat with a flat latex-acrylic interior paint, topped with water borne floor poly. If the boxes are nice wood, then just the poly. I do nothing to the outsides.
Clint
Sealcoat Shellac; quick dry, no lasting odor
Dave Bair, Eaton Rapids, MI
Hank Knight
>I finish mine with shellac. If the bottom is solid wood, apply the shellac before you put the bottom in the drawer to avoid gluing it to the sides. I apply a thinned coat of shellac to the end grain of the drawer front to seal it and then carefully apply whatever finish to the end grain I'm using on the drawer front. The thinned shellac will seal the end grain and keep it from absorbing too much finish and becoming noticeably darker then the rest of the piece. Then you can just go over the whole side, dovetails and all, with a coat or two of shellac. I usually use Zinsners (SP?) Seal Coat. It really just a sealer rather than a heavy shellac finish. When it's dry apply a coat of wax and your drawers should slide nice and easy.
Fred Davis
>Finish on a drawer side and inside bottom looks nice but is not necessary.
On the other hand when I use a good looking wood for the drawer box per se , like quarter sawn Sycamore, I will use the same Lacquer finish on the drawer parts as the rest of the case because it "pops" the grain of the wood.
I am presently making a copy of Glen Huey's 12 drawer Triple Dresser and the dovetailed drawer box is Maple and I am still thinking about the drawer parts finish or lack of. ;-))
The applied front is Pecan and naturally will be Lacquered.
FredD
