We value your privacy.
>I noticed recently that one of my sprinkler zones doesn't come on. I didn't own the house when the system was installed so I have no idea where this valve is located. I've found 2 of the 4 in the system and they are not near each other.
>It should be some where around the sprinkler motor Look for a box with a green lid on it Maybe a electric or manual type of sprinkler system ?? Look for a timer box Try and follow the wires to some where if electric switching valve's ? If manual type look for a unit that has the white pip's comming out of it count them maybe 4 or 6 pipes don't know how many zone's If it is a manual type It may not be switching The pump has to come to a stop for probly a min or so to let the preasure come to no preasure on the zone and than the pump should come on again That is when it switch's zones It may have to have the valve cleaned in the unit It may be stuck You didn't say if all zone's come on Not just 1 zone If just 1 zone doesn't come on Sound's like a electric type If so You will have to find the zone and head It is a coil May be open ?? that is about all i can tell you tell i know which system you have hope this helps
>Unless it was a DIY, the controls box should have an installers's sticker on or inside it. A commercial installer should have a layout of the system in their records.
>The stud finder that I have is supposed to be able to follow wires inside walls. I wonder...would it be powerful enough to follow buried controller wires???
>The installer than put in our irrigation system was in the habit of placing the solenoid valve boxes out in the yard. I had him place ours nearer to the house where they would all be located in the front mulched planting bed. For a few years I left the covers exposed but eventually, finding I seldom needed to access them, I covered them with mulch.
Now nobody would know where they are by looking. I would suggest if there are planting beds in the area of the zone that's not working, you might try probing those areas with a metal rod or long screw driver to see if it's buried just under some mulch or something.
>the underground utility guys use a tool that traces an underground cable or plastic pipe. Basically, if you install a buried gas line these days, the plumber will bury a copper wire in the trench. To trace the location of the pipe, you clamp a tone generator onto the end of the wire and then use a wand to follow the pipe.
Same principal will work with the sprinkler system. You can clamp the tone generator onto the wiring for the solenoid and map your system.
Two options are 1) rent a unit or 2) hire a plumber who has a unit and pay him to come out and spend 30 minutes
